Thread Tools Rating: Thread Rating: 59 votes, 5.00 average. Display Modes
Old 04-22-2012, 05:55 PM   #1171
nylko
hey anyone there still looking for some info
nylko is offline   Reply With Quote
Old 04-23-2012, 12:15 PM   #1172
Originally Posted by nylko View Post
hey I own a 1991 E30 318i convertible I have a set of 16x7.5 et40 on original suspension set up so I'm not sure what size tires i can use. I don't plan on doing any major modifications like fender rolling but i do plan on maybe going to some JOM coilovers in the future.
So i was just wondering what size tires i can run.
Thanks,
Nylko
You need spacers to mount them. 15 or 20mm. 205/50, 215/45, or 225/45 tires will work with either spacer choice.
Old 04-23-2012, 12:16 PM   #1173
Originally Posted by L8 Apexr View Post
What would the dead on offset be to fit 235-40-17's all around on an ordinary 325is?.I'm pretty certain the car will be coming to visit you and your fender roller in the future.
+25. See the Apex Arc-8's in 17x8 +25, they were made with input from some awesome wheel fitment guy as the ideal E30 non-M wheel for big rubber.
Old 04-23-2012, 08:29 PM   #1174
johnnycheeze
hi .. need to know if those will fit? and what tire size should be the best to fit these on an e30
thanks
enkei 92 15x8 offset 25mm
http://www.1010tires.com/wheel.asp?w...D+Silver+Paint
johnnycheeze is offline   Reply With Quote
Old 04-29-2012, 08:45 AM   #1175
E30isKing
Wheel Spacers
Hi there,
I want to put some wheel spacers on my E30...
My wheels are 7J 15'', wrapped in 205/50. Will some 2,5cm spacers work on the back? I want a nice stance without comprimised performance...
What would you suggest for the front?
Thanks again for this awesom thread and sharing of personal time and experience.
Paulo
E30isKing is offline   Reply With Quote
Old 04-29-2012, 01:45 PM   #1176
L8 Apexr
Hmm,wonder who they found to offer such good advice??.
I was kinda looking at the xxr 530's(not sure if I prefer wheels with lip or concave on e30)in a 17x8.25 +25 for the front and the 17x9.75 +35 for the rear.
Bad idea??.
L8 Apexr is offline   Reply With Quote
Old 05-01-2012, 02:06 PM   #1177
thanks
3mm front spacer to clear the struts. 205/50 if you don't want to roll your fenders.
Old 05-01-2012, 02:06 PM   #1178
Originally Posted by E30isKing View Post
Hi there,
Paulo
Need the offset of the wheels first.
Old 05-01-2012, 02:07 PM   #1179
Bad idea??.
Yup, those work well. 215/40 front 235/40 rear. You might need small (5-10mm) rear spacers to clear the trailing arms depending on the tire used.
Old 05-01-2012, 02:54 PM   #1180
E30isKing
my bad...
ET24
Old 05-01-2012, 02:59 PM   #1181
my bad...
ET24
25mm is possible on the rear with a flat fender roll and coilovers. Otherwise, I'd suggest 15mm front 20mm rear. You'll still need a small rear roll if you're low.
Old 05-01-2012, 03:51 PM   #1182
L8 Apexr
Thanks,now to save some money.
Old 05-04-2012, 09:27 AM   #1183
Jeff2886
Question about spacers and extended wheel studs
1) 10mm spacers on all 4 corners with 7Jx15" wheels (FWD offset that I can't remember off the top of my head right now).
2) 225/15 NT01s
3) GC Coilovers
I'd like to know if I need extended studs for these 10mm spacers.
Jeff2886 is offline   Reply With Quote
Old 05-07-2012, 04:10 PM   #1184
2) 225/15 NT01s
3) GC Coilovers
Yes.
Old 05-15-2012, 11:38 AM   #1185
zig553
Just wondering what it will take to get these wheels to fit on an 1987 325IS http://www.1010tires.com/wheel.asp?w...etrack+-+White Is there 2 different offsets for the front wheels and rear wheels too? Will I need 2 seperate types of spacers? Should I run a wider wheel in the rear?
zig553 is offline   Reply With Quote
