Old 03-27-2012, 06:28 PM   #76
e30_kid89
The Afro-stig
e30_kid89's Avatar
Originally Posted by sb_600 View Post
M52 cams won't fit in a non-vanos M50
from the pics it looked like he was using a vanos m50 for the build....not sure if things have changed since
Old 03-27-2012, 10:30 PM   #77
nate_s89
I should be able to hook you up with something. I'll let you know by the end of the week.
Originally Posted by e30_kid89 View Post
I have a set of stock 328 (m52) cams.
free if you pick them up!
Thanks for the help guys appreciate it, but I managed to grab one today.
If anyone has a diff though I am on the hunt, it is the last thing I need to get this project rolling.
nate_s89 is offline   Reply With Quote
Old 03-28-2012, 09:15 AM   #78
sb_600
sb_600's Avatar
open or LSD?
Shawn
Old 03-28-2012, 11:12 AM   #79
nate_s89
Open, and the lowest ratio possible ideally.
You have any diffs you want to part with?
And a question about oil, I know this topic has been beaten to death, but did you run anything specific for your break in period?
I usually run 15-50 Mobil 1 synthetic, was just going to stick to that.
Old 03-28-2012, 05:11 PM   #80
sb_600
sb_600's Avatar
My buddy has a 3.91 open diff - is that too short?
For break in, I did this: http://www.mototuneusa.com/break_in_secrets.htm and ran the crappiest dino oil I could find (Formula 1 i think - from CT), then right after, switched to AMSOIL 20W50.
I used the dyno strategy but did it on an airport runway, without the cool-down in between (since I was actually driving, cooling wasn't an issue).
Shawn
Old 03-28-2012, 09:47 PM   #81
nate_s89
Awesome thanks for the info, I will read it over.
Nah I need something like a 2.93, I just sold the 3.91 I had in it. I have a 5 hour drive to the cottage every weekend I want to be able to cruise comfortably.
Old 03-29-2012, 09:51 AM   #82
sb_600
sb_600's Avatar
LOL yeah my bad... turns out it was to Jamie that you sold it
Shawn
Old 03-29-2012, 12:14 PM   #83
nate_s89
Haha that is correct. Has he gotten it in the car yet?
Old 03-30-2012, 02:55 PM   #84
sb_600
sb_600's Avatar
not sure actually!
Shawn
Old 04-01-2012, 06:01 PM   #85
nate_s89
So I got everything put back together, fired it up and it started!
Except its throwing code 1281, which is DME controle module memory supply. Does anyone have any idea what could be causing this?
Car also wont idle and is running pretty rough.
Old 04-01-2012, 06:37 PM   #86
sb_600
sb_600's Avatar
I was getting that same code when I rebuilt my engine.... basically you just have to have the ECU cleared. It has to do with having the ECU disconnected with the key on or something like that.
Shawn
Old 04-01-2012, 07:41 PM   #87
nate_s89
Awesome thanks, I was getting kinda worried. How do I get the ECU cleared?
Old 04-01-2012, 07:41 PM   #88
sb_600
sb_600's Avatar
You either need a Peake code reader, or a BMW code reader
Shawn
Old 04-02-2012, 08:03 AM   #89
nate_s89
Once I get a diff I think I will drive it over to BMW and get them to clear it. I realized last night I hooked up the idle controller wrong and put both hoses into the manifold instead of one in the manifold and one in the rubber elbow before the throttle body.
Only thing I am missing now is the hose that goes into the hole at the bottom of the manifold closest to the firewall. Not the idle controller or the Intake Temp Sensor but there is a third hole, any ideas?
Old 04-02-2012, 06:35 PM   #90
nate_s89
Fixed the hose it idles now. It's just running rough and really rich. Did yours do the same before you cleared the dme?
