Old 03-21-2012, 10:40 AM   #46
Originally Posted by NOTORIOUS VR View Post
looking good! getting an adjustable cam gear I hope to at least correct for the timing difference from decking the head and block?
Yep. It's on the list of parts to buy. What one did you go with? The VAC ones are pretty expensive. I'm considering this one http://www.r-mracing.com/catalog/pro...products_id/33
Although I really am considering making my own seeing as this is all any place selling adjustable cam gears is doing...
I've heard bad things about the cheap ebay gears with the tooth patterns being off causing belts not to fit.
Old 03-26-2012, 02:58 PM   #47
Not too much to update about. I'm supposed to be picking up a flywheel tonight and will hopefully get into the shop tomorrow night to lighten it. Then I can get my crank balanced with the flywheel and get to assembling the bottom end. Also, a friend of a friend might be powder coating the block for me (depending on what he says it will cost).
Today at lunch I measured up my cam gear and drew this. It shouldn't be too hard to make with a mill and a dividing head.
Old 03-26-2012, 04:19 PM   #48
frankie591
let me know where you get your flywheel machined and how the price/quality is. I'm gonna need to get mine done for my m52 swap.
Old 03-26-2012, 04:36 PM   #49
I'm going to be doing the lightening myself at a friend's shop. I'm not sure if they can do it, but give Heimpel Automotive a call. They decked my block and head and I was satisfied with both the price and the quality of work. If they say they'll send it out to be done they are more than likely sending it to Forest and Forest Racing. They are located in Ayr. That's the shop where my crank is getting balanced. I haven't gone to pick it up yet so I can't comment on their work but the gentleman I spoke with at the shop was friendly and knowledgeable.
Old 03-27-2012, 12:33 PM   #50
Quick update. I picked up a flywheel last night. It weighed in @19lbs (as expected). I am going to be lightening it this evening and will update with the after weight and pics tomorrow.
Just a side note. The shop I picked up the flywheel from is located in Mississauga and is called KTM Motorworks. It's a one man shop and the guy who runs it is an E30 nut, he's got a built Turbo M20 in the shop that he told me put down 500hp on pump gas last year. He told me he's planning on getting a better turbo and some race gas this year for some serious power. Overall he was a nice guy to deal with.
Old 03-27-2012, 01:46 PM   #51
noodles101
ΛΦΕ
noodles101's Avatar
^^ i think i saw you bombing it on 401 west last night , u got off at guelph exit i believe.
Old 03-27-2012, 03:23 PM   #52
Probably. Would have been around 9:30ish.
Old 03-28-2012, 08:52 AM   #53
Flywheel updates:
Started by turning down the step
Then I cut away some of the middle
Finished result
I just weighed it and it came in at 15lbs. This was my first attempt at lightening a flywheel so I was conservative with how much material I removed. I definitely know where the other pounds can be removed next time around. However for now I'm happy with a 21% weight reduction.
The flywheel and pressure plate are going to get balanced with the crank this evening.
Old 03-28-2012, 10:13 AM   #54
BMe30
all by chance...
BMe30's Avatar
This will decimate all
Old 03-28-2012, 10:49 AM   #55
Looks good man!
Dare I squeeze
Old 03-28-2012, 11:18 AM   #56
nate_s89
Looks awesome, I'm jealous of the machine shop hook ups.
nate_s89 is offline   Reply With Quote
Old 03-28-2012, 12:05 PM   #57
You work at Linamar, just make friends with the guys who work on the manual mills and lathes if you have them at your shop
Old 03-28-2012, 12:11 PM   #58
El Gato Liso
El Gato Liso's Avatar
the light fly wheel feels so different...drives like a 4 cyl, moves like a six
i think when i yank my engine out im gonna have my pops lighten my flywheel even more! i only shaved of 3mm.
can't wait to see this project done brooo
***E30 part out to come. Gimme a PM for any inquiries!***
Old 03-28-2012, 12:11 PM   #59
nate_s89
^^I wish I had the time to make that happen. Contract is up here shortly I am moving to Michigan for another one. Will have to start over again on trying to get the perks haha.
Old 03-28-2012, 01:00 PM   #60
The 4 cylinders actually have pretty heavy flywheels to help them get off the line smoothly without having to rev them too high. A lot of the M42 guys do lightened M20 flyweel swaps.
Talk to the guys at McLaren Performance they build trick motors for a living
