Go Back   maXbimmer Forums > Classifieds > For Sale > Suspension & Brakes
Old 10-01-2011, 09:49 PM   #1
bmw whore
megan racing coilovers
For BMW All 3-series models 1999-2005 excluding AWD and M3 models
SPRING RATES:
F: 62mm ID; 180mm length; 7 kg/mm
R: 62mm ID; 160mm length; 8 kg/mm
DAMPER SPECS:
F: 110mm stroke; 240mm length; M2 valving code
R: 170mm stroke; 170mm length; A13 valving code
- 32 Levels of Damper Force Adjustment
- Pillow Ball Upper Mounts
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
(was installed this year in February)
asking $700.00
bmw whore is offline   Reply With Quote
Old 10-02-2011, 04:26 PM   #2
bmw whore
Bump need them gone
Old 10-04-2011, 09:20 PM   #3
bmw whore
Old 10-05-2011, 01:06 PM   #4
bmw whore
Price drop 550
Old 10-06-2011, 11:10 PM   #5
Ahctuning
Ahctuning's Avatar
How old is your set and any issues with the c/o set and in the install? I've read of some defects in some of them that you have to drill a hole or dremmel the holes so as to make the matching holes line up for the bolts to go thru?
Maybe the defective ones were from the early production runs in 2005-2006 or may not even be applicable to e46 application?
Like i said i've just read them on the net. I can be totally wrong. Shed some light if you will/care
Ahctuning is offline   Reply With Quote
Old 10-06-2011, 11:25 PM   #6
bmw whore
had no issues at all installing fit prefect had then fer less the 20k
Old 03-25-2012, 10:36 PM   #7
specialist
where are you located? pm me
specialist is offline   Reply With Quote
Old 03-26-2012, 12:25 AM   #8
bmw whore
Sorry I should have updated the status but they are sold
