Old 03-21-2012, 01:35 PM   #1
sparf328
boostjunky
sparf328's Avatar
Imaginary turbo build
just incase i win the lottery, i wanted to compile a list of the most insane uber expensive, turbo parts and random other e36 parts, figured there would be other people who have had this day dream cross there mind. I'm sitting in class bored as hell, and this came across MY mind.... I'm going to start making the imaginary build list later....
sparf328 is offline   Reply With Quote
Old 03-21-2012, 02:49 PM   #2
sparf328
boostjunky
sparf328's Avatar
http://www.youtube.com/watch?v=327C2qvIvz8 something along the lines of this build, i don't know if this has ever been posted on this forum before, but if no body knows the story behind this car it is extremely sad, shortly after completing the car, it was completely torched in an accidental garage fire.http://forums.bimmerforums.com/forum....php?t=1570818 go to post 26 not page 26, so sad
Old 03-21-2012, 03:32 PM   #3
325isdan
Well you mightest well go turbo and super charger to even out the lag.
Old 03-21-2012, 03:37 PM   #4
If money was no object, ship your car to TRM, they've built many e36 turbo setups: http://www.racersmarket.net/
If you wanted to spend even more money and be a little unique: Swap an s54 into it, and then convince the guys at HPF to fit a turbo to it, their e46 m3 turbo kits start at $13.5k + install. http://www.horsepowerfreaks.com/
Old 03-21-2012, 03:41 PM   #5
sparf328
boostjunky
sparf328's Avatar
i need a turbo e36 so bad
Old 03-21-2012, 08:21 PM   #6
Steve30
Techno Viking
Steve30's Avatar
ICS, CES, or TRM are all great for turbo S52's. Personally, if I were to turbo my car I'd get in tourch with ICS. George seems to know S52's very well and how to make insane power out of them. S54 turbo go speak with Mr.Radowski He's working on a stock DME tuned turbo setup that should take a dump on anything else out there. The recent drama with HPF and proEFI is pretty scary!
E36 ///M3 S54
STock 335i "The Punisher"
Old 03-21-2012, 08:48 PM   #7
Link? Haven't been in the loop on that...
Old 03-21-2012, 08:50 PM   #8
Steve30
Techno Viking
Steve30's Avatar
Grab some popcorn http://forums.bimmerforums.com/forum....php?t=1802848
E36 ///M3 S54
Old 03-21-2012, 09:19 PM   #9
Thanks, will read it tomorrow if Im not busy at work.
Old 03-21-2012, 10:36 PM   #10
Can someone give me coles notes? Cx took HPF car to 3rd party, they ****ed with it, it blew up, HPF fixed it. Did i miss something?
Old 03-21-2012, 10:54 PM   #11
DIY
Permanently Dirty
DIY's Avatar
O ringed block
10:1 compression
15lb of boost
9000RPM valve springs
A proper sized ball bearing turbo
Forged internals
Whatever intercooler fits
Drysump oil system
Cryogenically treated engine componenets
And fuel injected headers (ie put inejectors before the turbine, for some sweet antilag)
Added with some gangster shrouding for the cooling system
And you have the best turbosystem for anything ... It won't last long but if I could afford to rebuild my turbos often, and my engine every 5-7 track events, that's how ied do it
Old 03-21-2012, 10:54 PM   #12
Steve30
Techno Viking
Steve30's Avatar
HPF blamed the tuner while the tuner blamed the engine builder. It looks like there was excessive piston to wall clearance and the rings were gapped too tight. They are also suggesting that the s54 doesn't work well with sleeves which cracked and warped. In my opinion it's both shops fault. The engine was designed to run on aem but the owner decided remove aem and use proefi to tune on e85. He should've just let HPF fix the car which I'm sure Chris would have. By removing aem be pretty much voided warranty...
E36 ///M3 S54
Old 03-21-2012, 11:04 PM   #13
DIY
Permanently Dirty
DIY's Avatar
Topped off with a motec ecu and datalogger
Maybe RC injectors
Electronic boost control
Silica filled valves (I think that's the right term)
Titanium exhaust
Etc...
Want to go natually asperated? I could do this all day lol
