Old 02-14-2012, 05:58 PM   #1
slickdaddy
2004 330i hard start hesitation
Hello ,
I have a hard start issue on 2004 330i. it will finally start after hitting the gas pedal. then the idle is sporadic unitl I hit the pedal again. then it seems fine. I also get hesitation while accelrating. No warnig lights are coming on the dash. Anyone have any opinions ? could this be the Vanos? or cam sensor?
slickdaddy is offline   Reply With Quote
Old 02-15-2012, 11:43 AM   #2
jabela
Could be CCV/oil seperator issue due to cold weather. Check under your oil cap for yellow sludge or water drops. Also check for oil leakage from your valve cover. Running your engine hard for an hour may help burn off water/ice.
www.maisonapothecare.ca
Old 02-15-2012, 12:06 PM   #3
Pierce330
Pierce330's Avatar
Check your plugs and coils...your car sounds like it's misfiring...
E46 330i (Sold)
E90 328i (Sold)
E90 325i (Sold)
E90 328i Xdrive (Current)
Pierce330 is online now   Reply With Quote
