Old 01-25-2012, 10:56 AM   #1
Adrian_Lindn
Adrian_Lindn's Avatar
Reset Oil Maintenance km on dash
I changed my oil and need to reset the km since the dash tells me I'm 4000km over due for an oil change. Is there a DIY for to reset this?
Adrian_Lindn is offline   Reply With Quote
Old 01-25-2012, 11:22 AM   #2
MANDD
Autobahn East
1. Press odometer reset button on the left and hold
2. While holding the odometer reset button turn key to position 1 (ACC).
3. Keep holding button until service interval "reset" displays, then release.
4. Hold button in again until "reset" flashes
5. Now release and press odometer reset button once and release. You next service will be displayed and you are done.
Mark.
MANDD is offline   Reply With Quote
Old 01-25-2012, 06:40 PM   #3
DaveM3_09
DaveM3_09's Avatar
Will this procedure work for the m3 as well?
DaveM3_09 is offline   Reply With Quote
Old 01-26-2012, 09:29 AM   #4
MANDD
Autobahn East
Yes
Old 01-26-2012, 07:12 PM   #5
yung
Mark.
will this work on e36!? cuz that would be awesome
yung is offline   Reply With Quote
Old 01-26-2012, 07:47 PM   #6
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
^^Pretty sure you do yours like this.
http://www.unofficialbmw.com/e36/ele...ce_lights.html
BTW, if you jump pin 7 to pin 19 (19 is a ground), with a piece of wire, that should do the trick. It's the same as late model e30s. Google is your friend.
Grow up and move on.
Old 01-26-2012, 10:55 PM   #7
MANDD
Autobahn East
No. The e36 is quite different, use a test light. Ground the test light clamp and probe pin 7.
Hold about 5 seconds for oil service and 7 to 10 seconds for inspection.
Mark.
Old 01-27-2012, 02:09 PM   #8
E30M42cab
E30M42cab's Avatar
That's what I just said.
Old 01-27-2012, 04:42 PM   #9
Adrian_Lindn
Thanks Mark! it worked!
Old 01-28-2012, 10:18 AM   #10
GTA_G20
Autobahn east for the win!
04 BoxsterS, 95 325cab
GTA_G20 is offline   Reply With Quote
