Old 01-10-2012, 01:13 AM   #16
Blades
Your opinion is to long
Blades's Avatar
Originally Posted by jmack View Post
I'm on my second 540i so I'm a lost cause... But yeah the first six months of my first 540 were brutal. So far I'm at $600 for #2. I'm doing as much DIY as possible.
I would love to see the costs of a used 540 for 2 years. I always wanted to get one but was afraid of the costs compared to a 3 series.
-=[ BL/\DES ]=-
Old 01-10-2012, 01:38 AM   #17
jmack
I'll let you know in two years... hah. My first 540 I only had for six months then sold it due to moving up north of Kingston where I just couldn't use the car at all.
Pre Purchase Inspection $225
Maint Parts (air filters, spark plugs etc) $300
Peake Scanner $200
Oil Change $120
Inspection II + thermostat + some other stuff $1100
Tires $600
Thule Roof Rack $700 (not really maintenance but was needed for me)
Even with that I didn't even get to do any of the real deferred maintenance work to the car, which would have involved changing out all the engine gaskets save for the head gaskets and oil pan gaskets. Crank sensor, cam sensor, maf and temp sensor was replaced to bring it up to spec. That's $500-700 in parts right there. The guy I sold the car to ended up taking care of that stuff... Bottom line is make sure you can a) DIY and b) have some money set aside for bringing it up to spec. Most 540s would also need a complete cooling system overhaul if not done already, that's $800-1000 right there if you do everything, parts only.
jmack is offline   Reply With Quote
Old 01-10-2012, 01:47 AM   #18
With the 4.4 its always a hit or miss situation after 180K...Both engine and auto transmission! The rest of the car is all small things, nothing that you cant DIY. If you want a reliable E39, find a clean 96-98 528i, the older driveline was pretty much bulit proof. For the lack of power, just add a blower to it and you have 540 Hp without the agravation!
