Old 12-30-2011, 11:33 PM   #1
5style
Hatters gon Hatt
5style's Avatar
Mein 318is+winter work begins
First order of business, bought diffuser from Euroguy, installed!
Old 12-30-2011, 11:35 PM   #2
5style
Hatters gon Hatt
5style's Avatar
garg, well, good thing my exhaust has holes, because now i can replace it with one from a m50 or m/s52. Will fill in diffuser gap!
Old 12-30-2011, 11:51 PM   #3
5style
Hatters gon Hatt
5style's Avatar
Bodywork: rust bubble under door on rocker cleaned off, acid sprayed. Now, need to mask off, and touch up! No more nasty bubble! The dirt towards the indicator on the same panel is just that , dirt
Old 12-31-2011, 02:44 PM   #4
sproule905
sproule905's Avatar
Des the 318's of that year allow for an oem m3 exhaust? That would definitely fill the gap.
Old 01-01-2012, 08:12 PM   #5
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Konrad, should have told me you wanted a 6cyl exhaust, I have a 328i exhaust you can have for next to nothing (no use for me and taking up space).
Old 01-01-2012, 08:52 PM   #6
jon.e
jon.e's Avatar
So the m3 diffuser fits a non m bumper? Easy bolt on? Or is that an m bumper?
Looks good! Seen you a couple times on the dvp. Car looked good man!
E36 s52 powered 328i - track car
2002 Honda civic si veloz- DD
jon.e is offline   Reply With Quote
Old 01-05-2012, 09:12 PM   #7
5style
Hatters gon Hatt
5style's Avatar
Almost, will need one y-pipe from single to dual
Old 01-05-2012, 09:13 PM   #8
5style
Hatters gon Hatt
5style's Avatar
When i am back from ottawa , we shall talk lol
Old 01-05-2012, 09:14 PM   #9
5style
Hatters gon Hatt
5style's Avatar
It doesnt, i have a m3 rear bumper too. I suggest you get the m3 lookalike diffuser for the stock bumper, its much cheaper and alot less effort!
Thanks btw!
Old 02-07-2012, 01:50 AM   #10
5style
Hatters gon Hatt
5style's Avatar
M3 mirrors (not pictured) and OEM clears installed. Need to buy some offset front lolly bushings, anyone have any? Still collecting parts for the rear suspension, hub, brake and bushing swap. All I need for the front now, are the bushings tho.
Old 05-20-2012, 01:48 AM   #11
5style
Hatters gon Hatt
5style's Avatar
Time to update and throw up more pics!
Front end is completely new minus Shocks now.
-New Tierods ( Inner and outer)
-New control arms
-Offset Lcabs
-New sway bar links
-New Sway bar bushings
-New ball joints.
WHAT A DIFFERENCE!
New rotors on the front,new pads and new M3 calipers added.
-M3 mouldings! ( Finally)
Power steering leak delete and clean up ( washed the reservoir, hoses and eliminated those nasty leaks from the reservoir!)
To those that don't know, in 80% of e36s it is just a case of failing hose clamps on the reservoir side)
.99 cents for new ones out of stainless steel
I flushed the system as well, new fluid and everything is nice and dry!
Valve cover gasket is next and I can FINALLY detail the poor m42 to how it is suppose to look, not to mention my super filthy engine bay.
I am picking up a exhaust from Tomek to fill the diffuser gap and to get rid of my fartcan due to a huge hole from rot.
Rear suspension part collecting is almost done and I can do the rear M sway arm swap along with brakes.
I think the hardest part will be swapping out the master cylinder! gulp
Red gauge needle mod is complete! If anyone wants red needles, I can do a conversion for $30 ( no , not paint, yes, 100% like oem)
I have also started to insulate the interior, starting with door panel moisture barriers. I ripped the crappy ones out, cleaned all the glue, got NEW glue and used a two sheets of heavy gage vinyl stuck to 5 mil thick waterproof foam. Vinyl faces outwards towards water, foam towards door panel. The difference is MASSIVE. The interior now have numb areas where there is zero noise present from outside.
Pics to come tomorrow
Old 05-20-2012, 01:57 AM   #12
5style
Hatters gon Hatt
5style's Avatar
New Mouldings:
Prepping new rotors for install ( Protection from rot)
Old 05-21-2012, 03:45 AM   #13
Axxe
Axxe's Avatar
Looking good!
Old 05-23-2012, 01:28 PM   #14
5style
Hatters gon Hatt
5style's Avatar
shit shit shit brow, totally forgot to get back about exhausts, i shall txt you today once im at work!
Old 05-23-2012, 01:30 PM   #15
5style
Hatters gon Hatt
5style's Avatar
Ok, leaky power steering FIXED.
