Old 12-27-2011, 05:01 PM   #1
noodles101
ΛΦΕ
noodles101's Avatar
will this electric fan fit?
http://www.ecstuning.com/BMW-E36-328...Fan/ES1892549/
will that e fan fit on my stock rad??
or do you think i have to get mishimoto rad to fit it?
also do i need a fan delete do fit that fan unit?
thank u guys in advance
Old 12-27-2011, 05:05 PM   #2
noodles101
ΛΦΕ
noodles101's Avatar
probably a good idea to do a fan delete if i wanna fit that unit. no need for mech fan.
Old 12-27-2011, 08:31 PM   #3
5style
Hatters gon Hatt
5style's Avatar
measure! you can always make custom brackets no problem.
Old 12-30-2011, 07:45 PM   #4
You'll need to delete the clutch fan to fit this, and yes it will fit your stock rad. But you won't be able to run the OEM coolant tank.
Old 12-31-2011, 01:27 AM   #5
noodles101
ΛΦΕ
noodles101's Avatar
^^ thanks kurt, u think its better to just buy a regular e fan so i can run my oem coolant overflow tank? regular e fan is way cheaper then this kit with aluminium tray...
Old 12-31-2011, 02:13 AM   #6
Ya I'd definitely just mount a fan right to the rad. I did that with the yellow car and it worked perfectly.
Old 01-02-2012, 01:27 PM   #7
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I have a 14" puller right now (16" wasn't in stock when I needed it), so I plan on getting the mishimoto 16" with shroud and running a euro expansion tank and deleting the secondary air pump.
