Old 10-13-2011, 09:34 AM   #1
ismail
ismail's Avatar
Clutch Issue??
Hi All,
Just looking for some help on an issue I am having with my 328is, and I am not sure whats causing it. I am thinking it might be one of the slave cylinders and here is why.
1. Clutch has a very high engagement point, so much so that I have to move my entire leg because the engagement point is so high. (Hydraulic clutch cannot be adjusted)
2. Clutch does not slip, have tried multiple times on all kinds of launches
3. When the car is cold,
a) Have difficulty getting it into reverse and
b) On cold mornings like today, I have to clutch and de-clutch multiple times for it to go into gear - in particular when downshifting.
4. Just changed the clutch/ brake fluid to RBF600, could it be that this fluid takes longer to warm up and thats the issue?
Anyway hoping to hear some feedback on what you guys think the issue might be.
Thanks,
Ismail
ismail is online now   Reply With Quote
Old 10-13-2011, 09:40 AM   #2
sproule905
sproule905's Avatar
mine does that sometimes in the cold, but I just think its the syncros. Mines a 99, but its never slipped out of gear. Just have to be patient when going from R to 1 when its cold.
Old 10-17-2011, 11:39 AM   #3
ismail
ismail's Avatar
Thanks for the response....
Thank you for the response, just want to get additional feedback if anyone else has had this issue, or how they resolved it.
Its quite embarrassing to stop at a stop sign/ traffic light and not be able to get started right away, because your sitting there double and triple clutching every morning.
Thanks in advance.
Old 10-17-2011, 06:58 PM   #4
sproule905
sproule905's Avatar
Are you a first time 5 speeder? try changing the oil - very inexpensive and might free up some of the stickies..
Old 10-17-2011, 10:23 PM   #5
Discostar
Discostar's Avatar
It could possibly be a weak clutch master cyl.
I am experiencing the same problem. Just swapped in a six speed and my clutch master cyl. is not properly sized yet. But the Getrag is also known to be notchy, so who knows.
Old 10-18-2011, 02:58 AM   #6
jeffrie
Addict
jeffrie's Avatar
Think you need the 6 speed slave as well, sounds like it'd barly engaging the clutch making all gear changes difficult.
Simple slave cylinder leaking will do that OP, possible air in system if not leaking.
Pull up the carpet behind the clutch pedal if all oily the slave is leaking. Unfortunatly a common fault for BMW's in any year
Old 10-18-2011, 08:47 AM   #7
ismail
ismail's Avatar
No, have owned 5 speed in almost everything I have owned prior to this Jettas, Corrollas, Mazda3s. Oil has already been changed in both tranny and clutch system.
Which 6 speed master/ slave cylinders will fit???? Will one out of an e46 fit or even an e90, and if so do you have the part numbers?
I was thinking it was one of those as well because the clutch doesn't slip, and now it seems its happening even after the car is warm that all shifts are difficult.
Old 10-18-2011, 08:48 AM   #8
ismail
ismail's Avatar
Btw....thanks for all the responses and help, much appreciated in trying to get to the bottom of this.
Will look at the slave first as that is the cheaper part.
Old 10-18-2011, 11:00 PM   #9
Discostar
Discostar's Avatar
I'm pretty sure that comment was for me. The Stock e36 M3 Master cyl is properly sized for the 6-speed when paired with the 325is slave cyl. I have the 325is master cyl right now. So it doesn’t feel right, and I actually had better feel with the stock 300k gearbox and clutch.
Ismail, you may be right, perhaps its the clutch slave and not the master.
