Old 10-05-2011, 12:12 PM   #1
SAVAGE
2001 convertible top wont close or open
So this morning I went to the garage to close the top on my car cause it was to cold to drive to work. i placed the key in the door lock and turned to the lock position. Hatch opened and the top started to raise. Half way through my hand slipped and the closing operation stopped. turned the key to the lock position again to continue the closing process but it wouldnt continue. Tried to reverse the process to open the top but it wouldnt move.
I didnt hear any clicks or knocks to indicate something went wrong.
turned on the vehicle and tried using the interior buttons and nothing again.
If this has happened to you, let me know what the fix could be and how much.
I had to take my parents vehicle since it wouldnt be safe to drive.
HELP HELP
SAVAGE is offline   Reply With Quote
Old 10-05-2011, 12:14 PM   #2
Get in the car, start it, foot on the brake, lower the top and raise it again.
Old 10-05-2011, 12:15 PM   #3
SAVAGE
So you think the car thinks it's moving so it wont close?
Old 10-05-2011, 12:19 PM   #4
The whole auto-close process ****s up sometimes, just try to close it with the button in the car. There's also a point in the convertible top operation where its not closed enough for the system to try to open it, and not open enough for the system to try to close it. You can gently and slowly return the top to either opened or closed, and then try it again.
Old 10-05-2011, 12:22 PM   #5
SAVAGE
Thank you ill give it shot when i get home and let you know how it works out.
Hopefully thats all it is
Old 10-05-2011, 12:25 PM   #6
SAVAGE
Sorry to bother again.
since we are on the subject, is there anyway i can program my key fob to open close the top. at the moment the only way i can do it is to either press the buttons in the car or place the key in the door.
Old 10-05-2011, 12:54 PM   #7
I believe it can be reprogrammed on a e46, but i think only with a GT1. Give RMP a call and ask.
Old 10-06-2011, 09:35 AM   #8
SAVAGE
No luck.
i tried everything. Put my foot on the brakes and tried lowering it but wouldn't budge.
Manually closed the roof and tried opening it with the button in the cabin.
Manually opened the roof and tried opening it with the button in the cabin, the roof started to come up but it stopped before the rear window was clear of the compartment hatch.
i have no choice but to take it to the dealership or a convertible specialist.
Old 10-06-2011, 01:26 PM   #9
damameke
Originally Posted by SAVAGE View Post
No luck.
Try
http://www.encoautotrim.com/
I found this place while googling for a place to replace the rear plastic window of my top and I spoke to Peter, give him a call.
