Old 09-27-2011, 07:54 PM   #1
CoreyC
CoreyC's Avatar
Stripped torx in the sunroof motor - advice please!
Hi all, well, this summer my sunroof gave the proverbial CRUNCH! and wasn't retracting quite right.
I went for the quick fix - ordered the 'slide' parts for the sun-shade. But, mine were not broken. Found out the spiral coil is bunching. So, my cassette is cracked somewhere. No worries, I'll pull the headliner in the spring, and see if I can't fibreglass the cartridge back to snuff.
BUT - in all my frantic efforts, I stripped the manual adjust torx head in the sunroof motor. It's a very soft metal. Grrr....
I need help! The motor is fine! Anyone know if I can get a replacement torx bolt for the motor (fat chance I think....). Or, for the tool/die types, can I re-tap the stripped torx head?
Help please!!
Many thanks in advance!
Corey.
CoreyC is offline   Reply With Quote
Old 09-27-2011, 08:54 PM   #2
slemmer
Driving in the fast lane
slemmer's Avatar
can you cut a straight line with an abrasive wheel so that a flat screwdriver can be used?
'04 645cic (for sale)
'05 GMC Sierra SLT Z71 CCSB 4x4
'02 Regal LS
'00 740i Sport
'06 330cic vert ZHP (sold)
'00 323i (sold)
'99 328cic vert (sold)
Old 09-27-2011, 09:18 PM   #3
toy4to
I hate having stripped bolts. I've used the 'Grabit' line of screw/bolt extractors and it worked very very well for me. Canadian Tire sells it, under the house brand name. Use it with a drill and in reverse mode. Then flip over the bit and use the other end, but do it by hand with a bit driver and slowly you'll get it out! They have infomercials for this thing...but it works very well!
http://www.canadiantire.ca/AST/brows....jsp?locale=en
And a youtube video showing how to use...
http://www.youtube.com/watch?v=y8RCsu3BzUM
toy4to is offline   Reply With Quote
Old 09-27-2011, 09:42 PM   #4
Nick_V
Nick_V's Avatar
I've cursed BMW more than once for using those fasteners. If they are old they seem almost guaranteed to strip. I usually just clamp down as tight as I can on the bolt head with some vice grips - usually does the trick.
Old 09-28-2011, 07:38 AM   #5
CoreyC
CoreyC's Avatar
Thanks peeps. Slemmer, I'll try that.
I can't try the Grabit, or the vice-grips - this is the tensioner bolt (maybe I shouldn't call it a bolt). It actually stays in place in the motor assembly - but turns, and engages the threaded metal cable.
