Hey e36 crew. My OBC tells me occasionally that I should check my coolant level when I turn the ignition off. I've checked it when cold and it's dead on the "Cold" line. Sometimes the warning comes on, sometimes it doesn't. I remember having the same warning come on about 6 months ago and I added about 100mL of fluid and it went away.
Is it just that I'm on the edge of when the sensor goes off? Is it possible to have a leak so slow that the system loses 100mL over 6 months?!?
Hi tehskeo, I would first try and add a little bit of coolant and see if the warning goes away. And if you really want to see if there is a small leak in your system, you can always do a system pressure test to be sure.
^ this would be my guess. Same thing happened to my car - the wire at the connector was starting to go... sometimes it would work, othertimes not until it eventually failed completely and the warning was on all the time.
2002 330Ci (ex-daily driver - sold!) Check out my e36 track car build
