Old 08-02-2011, 08:48 PM   #1
Boxer2
The OPP loves my M5
Boxer2's Avatar
E38 M62 oil level reading to high
I have a customer looking into purchasing a 2001 740i which according to the current owner the oil level is reading to high. The correct amount of oil has been put into the engine but still reads to high....has anyone ever had this issue? looking for possible causes, any info would be appreciated.
My Garage:
1986 328is (M20 Stroker)
1986 535i (5sp all original)
1990 325iX (Mint 5sp all original)
1989 325iX (Winter auto X car)
1991 M5 x2
1988 M6
2001 740i (Supercharged)
1999 528iT (summer DD)
2004 X5 3.0i (winter DD)
Boxer2 is offline   Reply With Quote
Old 08-02-2011, 10:04 PM   #2
The correct amount of oil verified by you? If not, verify it yourself, maybe they put oil in the car while the front end was still jacked up. Another potential answer (although unlikely) is the dipstick was swapped with one that is slightly longer. Hopefully someone wasn't using conventional oil in it and neglecting oil changes because that could cause sludge build up in the oil pan not to mention the valvetrain.
Old 08-02-2011, 10:41 PM   #3
Boxer2
The OPP loves my M5
Boxer2's Avatar
no not verified by me, one of my regular customers called me today asking me questions pertaining to this issue, I also thought maybe the wrong dipstick, either way I would like to verify the car myself, and was looking for potential causes before the car comes in.
My Garage:
1991 M5 x2
1988 M6
Old 08-03-2011, 02:02 AM   #4
Dado 540
Dado 540's Avatar
check the part number on the dip stick.
E39 540i Sport
Old 08-03-2011, 11:53 AM   #5
Boxer2
The OPP loves my M5
Boxer2's Avatar
The owner is stating that there is pressure build up in the emission system causing the oil level to raise??? does this sound right?
My Garage:
1991 M5 x2
1988 M6
Old 08-03-2011, 12:08 PM   #6
If there was any substantial pressure in the crank case when the car was shut off (which seems unlikely) it would either seep past the rings or it would be released when the dip stick is pulled out.
Old 08-03-2011, 12:17 PM   #7
Boxer2
The OPP loves my M5
Boxer2's Avatar
I'm also thinking maybe the level was checked too soon after switch off so there would have been 'splash back' up the dipstick
My Garage:
1991 M5 x2
1988 M6
Old 08-03-2011, 03:47 PM   #8
Yeah, always wipe it off first, put it back in and then check the level. My car would always be overfilled if I checked the level based off of what I see when I first pull the dipstick out.
Old 08-16-2011, 11:09 PM   #9
Boxer2
The OPP loves my M5
Boxer2's Avatar
well I finally got a hold of this car, and I can't find any evidence of rising oil levels, my guess is this guy don't know apples from oranges when it comes to cars......turns out this car is in excellent condition, and was well looked after, all service records from day one are present, very nice E38
My Garage:
1991 M5 x2
1988 M6
Old 08-17-2011, 01:22 AM   #10
^ that sounds great!
Follow me on Instagram @SEVEN40iL and Twitter @SEVEN40iL
Old 12-29-2011, 04:05 AM   #11
Dammerung
Dammerung's Avatar
Anyone bothered to check the codes for oil pressure sensor?
Die Dämmerung..............when dusk began to fall, when dawn begins to break
Dammerung is offline   Reply With Quote
