Old 06-19-2011, 09:25 PM   #1
fitter527
hates chrome
fitter527's Avatar
trouble starting in hot weather
on really hot days,30+,it takes about a dozen or more tries to start my car.25-30,half dozen tries.under 25 the car starts first try.has anyone else experienced this before.
fitter527 is offline   Reply With Quote
Old 07-15-2011, 12:56 PM   #2
Surk
6 Spd Member
Could be your Intake Air Temp (IAT) sensor defective in intake manifold....this regulates what DME "thinks" should be cold\hot start..either that or you have a heatsoak problem..
Surk is offline   Reply With Quote
Old 07-15-2011, 03:46 PM   #3
Pierce330
Pierce330's Avatar
Could be the crank sensor!
Pierce330 is offline   Reply With Quote
Old 07-15-2011, 07:48 PM   #4
take it to a shop, fix it before you blow your starter. Cranking for a while on hot days = premature starter failure.
Old 07-26-2011, 12:34 AM   #5
sol_searchin
^Exactly, could also be a weak pump or a clogged fuel filter. Could be many things, but you will cause damage to your starter/kill your battery with the constant cranking.
sol_searchin is offline   Reply With Quote
