Old 07-10-2011, 07:40 PM   #1
rider-.
clutch not disengaging fully!
hey guys, so yesterday my clutch started acting up, i press the clutch pedal but the clutch doesnt disengage fully, so it is very hard to get it in gear, the clutch is only a couple months old, so i doubt that anything happened to it, so my mind is kind of boggled towards what could have come up all of the sudden, i checked the fluid and its full, and the clutch was bled properly when it was installed, any ideas?
Old 07-10-2011, 07:56 PM   #2
InfiniteDice
12 Years with the E30
InfiniteDice's Avatar
Did you put a new release bearing on? That is what actually slides and engages the clutch. The splines of the shaft when re-installed needs to be greased as well.
InfiniteDice is online now   Reply With Quote
Old 07-10-2011, 07:58 PM   #3
dcramer
Start with the simple things, bleed it again.
Dave
Old 07-11-2011, 06:49 PM   #4
Renboy
Also check to make sure the nipple on the end of the slave cylinder hasn't broken. Relieve pressure before removing the slave.
Old 07-19-2011, 05:56 PM   #5
rider-.
K so i still have the same problem after replacing the slave cylinder and bleeding it. How would i know if it is the clutch fork without physically pulling the tranny. I dont underdstand how it would get worse and worse over a week until it didnt engage at all though. Only thing that made sense is hydrolics but the slave is working and the pedal feels fine, i dont think anything is leaking either, only other thing could be that something physically broke on the master. Anyways, your thoughts?
Old 07-20-2011, 12:16 PM   #6
Renboy
Have you noticed any leaks by the clutch pedal?
Old 07-20-2011, 12:29 PM   #7
Sounds like the release bearing hanging up. take back to shop and have them inspect if a shop installed it they should be the ones to correct it.
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
