Old 06-07-2011, 10:54 PM   #1
iverson03tj
iverson03tj's Avatar
Alignment Specs
Hey guys, i just swapped in my rear end and changed a few front suspension and m3 brake upgrade... so now im shopping around for alignment.
What specs do i align the car for? i'm not really looking for anything aggressive, since this is my daily car that i drive about 60,000km a year in... so tire wear does matter a bit, especially since its lowered... and i don't have any camber plates or rear adjustable LCA's.
Any info would be much appreciated, Like if any one had good experience with certain shops, and what specs i should keep it at... i heard alot of people ging with 95 m3 specs, is there a reason for this?
PREVIOUS CARS
Old 06-17-2011, 04:27 PM   #2
sparkybp
Tortures BMWs.
sparkybp's Avatar
95 m3 specs most aggressive. front end requires offset lower control arm bushings. if you just want a little more grip in the corners don't bother. check the bentley manual as it has a complete specification sheet for e36 alignments including the m3. you may also want to google "the definitive alignment guide" for e36 m3.
Good discounts on all OEM and good quality aftermarket BMW parts. 519-498-9660.
Old 06-17-2011, 09:00 PM   #3
SiR
Vtec just kicked in
on bimmerforums
-||Old Crayons||-
Old 06-20-2011, 02:03 AM   #4
iverson03tj
ok thanks guys much appreciated!! anyone know a good alignment shop?
PREVIOUS CARS
Old 06-20-2011, 08:55 AM   #5
sproule905
sproule905's Avatar
woodbridge alignment.. no appointments.
Old 06-20-2011, 12:36 PM   #6
iverson03tj
Ok so i called up a few places and i found out something interesting... http://www.limitlessauto.com/wa.html They got camber kits for front and back for only $160... so im really thinking of going with this... has anyone ever tried these camber kits... its not camber plates or the lower control arm.. its just different eccentric bolts i belive.... And i would love adjustable ones but i cant justify spending 400 + for camber plates and lower camber arms.. if i get the same thing with the $160 kit....
My car is my daily driver and i do alot of highway driving.. and its lowered... so im going with what bf.c said and going with
Front
Camber: -2.5 deg (per side)
Toe: 0 (or 0.10 to 0.20 deg total toe in for mostly highway driving)
Rear
Camber: -1.5 to -2 deg (per side)
Toe: 0.20 total toe in (IIRC this is 1/8" total toe in)
I am going to do a lot of highway driving so im thinking 0.10 toe for the front.
For the rear camber should i go with -1.5 or -2 deg... what would be the advantages ---1.5 vs -2.0 deg?
PREVIOUS CARS
Old 06-20-2011, 01:34 PM   #7
ScotcH
They're called crash bolts. Basically used to compensate for bent components, but can be used to adjust things as well. You can also just use shims (ie, washers) on the front for more camber. Being lowered, you likely won't need too much to get to -2.5.
For rear, you won't need to do anything. it's already adjustable to about -2 for camber. I would stick with -2 in the rear. it's the M3 setup, and you'll get a bit more traction in turns. The setup specs you posted are great for a daily driver.
Old 06-20-2011, 02:51 PM   #8
iverson03tj
Ok thanks scotch, so i wont be needed the crash bolts on the rear (80 more bucks to spend on other parts)
And for the front i will tell them to put washers first before getting crash bolts
PREVIOUS CARS
Old 06-20-2011, 05:51 PM   #9
JunzieB
Wants more powaaa!
JunzieB's Avatar
http://www.e36-tech.com/forum/the-de...-e36-2102.html
Good call, found the information useful when i was looking into alignment specs.
Disclaimer:The opinions expressed by JunzieB is his alone and does not reflect the opinions of Maxbimmer or any members thereof. JunzieB is not responsible for any hurt feelings that may develop during the reading of his posts.
JunzieB is offline   Reply With Quote
Old 06-21-2011, 10:28 AM   #10
sb_600
sb_600's Avatar
With my car lowered on the eibach sportlines, I put 5mm of washers on the bottom two strut bolts (make SURE to get longer bolts - 25mm grade 10.9), and I had -2.8 of neg. camber up front. cost me around $10
Shawn
Old 06-21-2011, 06:51 PM   #11
325isdan
Just by washers and longer bolts and save yourself $75. those shim kits are a rip off.
