Old 05-28-2011, 05:46 PM   #1
Bigjohn88
Save gas need advice
I have ten years old e39 528i, it eat a lots of gas city and Hwy 13.8L/100Km. When it was new only 11.9L/100Km. I have spark plugs change, oil change, air filter replace and fill up 91 gas but it didn't change much. Can you guys tell me what else can I do to save some gas?
Thanks!
Bigjohn88 is offline   Reply With Quote
Old 05-28-2011, 07:15 PM   #2
BMW_7
Econobimmer Racing
BMW_7's Avatar
Checking the oxygen sensor is a good idea. Fuel injector, fuel pumps.. Try adding fuel stabilizer too?
Vitaliy
2000 Audi A8 SWB Silver/Black
1992 BMW 525iT/5 White/Blue [MPars, HIDs, cargo net]
1989 525i [scrapped]
1995 BMW 318i DASC [sold]
Old 05-28-2011, 07:20 PM   #3
Dado 540
Dado 540's Avatar
What size are your wheels and tires? Oversized rims or tires will increase fuel consumption
Is your thermostat working ok? If the theremostat sensor is shot it will cause an increase in fuel consumption.
Have you been messing around with the OBC? If you accidentaly changed the consumption factor (1000) it will increase the fuel consumption
E39 540i Sport
Old 05-28-2011, 07:33 PM   #4
new member
Replace fuel filter, clean MAF or buy a new one. SInce you already replaced the plugs this should be it.
Injectors dont get plugged in these cars, due to its design and if the fuel pump works then it works. Replace it when it stops working.
I guarantee that you will not only be satisfied after you replace fuel filter and MAF but your car will also feel much better.
new member is offline   Reply With Quote
Old 05-28-2011, 07:39 PM   #5
Bigjohn88
Thank you for all reply!
Old 05-28-2011, 10:33 PM   #6
Dr. Flyview
Formerly Flav_cool
Dr. Flyview's Avatar
I'm not contradicting you, but can you explain how a bad fuel filter actually makes the car use more gas?
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
sold
Dr. Flyview is online now   Reply With Quote
Old 05-28-2011, 10:43 PM   #7
new member
Clogged fuel filter will result in improper fuel pressure which leads to bad atomization of fuel which leads to bad mpg.
Its all in teh fuel pressure, low pressure will make you want to floor it because there isnt enough power produced etc, many bad things could result of dirty/clogged fuel filter.
