Old 03-31-2011, 06:08 AM   #76
Chris916
Chris916's Avatar
yes mucho fender flares!
there 16x9. cant wait to get some rubber on them!
Old 03-31-2011, 07:52 AM   #77
sb_600
sb_600's Avatar
and mucho body hacking. that's going to look so sweet.
Shawn
Old 03-31-2011, 05:12 PM   #78
ipop07
Spacers guy
oh that would be sweet..seriously awesome...put my sticker on your car when youre done hehehe..
ipop07 is offline   Reply With Quote
Old 03-31-2011, 06:05 PM   #79
Chris916
Chris916's Avatar
Yes mucho body hacking as well
thanks man! now what can you do for me
Old 03-31-2011, 06:22 PM   #80
ipop07
Spacers guy
well I doubt you'll need spacers for this thing haha..
Old 03-31-2011, 06:35 PM   #81
Chris916
Chris916's Avatar
Actually, i need a 10mm spacer to clear the fronts with 245's so ill most likely run 10mm all around. still need to test fit when i get the tires though before i pick some up. whats your company? or private?
Old 03-31-2011, 06:52 PM   #82
ipop07
Spacers guy
check your pm
Old 04-08-2011, 11:12 PM   #83
Chris916
Chris916's Avatar
The engine work begins!
Shawn and i pulled the head off the m50 today to see if we could determine the reason for low compression.
Pulled the Valve cover off, and to our surprise, the head was extremely clean!
Removed the head, cams, and cam trays.
Since the headgasket looked good, we tried a leakdown test to see if the valves weren't seating properly. to test this we pour gasoline over the valves to see if it leaks through.
Turns out the valves on cylinder 5 (the one with low compression) were not seating properly at all as the gas almost instently drained through as we poured it onto them. As it turns out, only cylinder 3 was not leaking through.
This is good news as its an easy fix. just need to lap the valves, throw a new headgasket, head bolts, and valve cover on and she should be good to go!
A couple shots of the block:
(sorry for crappy cell pics. i really need to get a camera)
Old 04-09-2011, 03:13 AM   #84
MBrown
MBrown's Avatar
sweeeeeeeeet, I gotta get my M3 out and over to your place asap! I'm probably going to go ahead and order a cooling system overhaul kit from bimmerworld and the UUC exhaust has to go on!
1995 US-Spec Boston Green M3
UUC System U Catback
Old 04-09-2011, 11:18 AM   #85
Shit son, this is going to be great!
Old 04-09-2011, 12:02 PM   #86
Chris916
Chris916's Avatar
Yea man you gotta get on that, its beautiful out!! Sweet! if time permits, we could definitely give you a hand getting her ready.
Thanks! getting exciting now. its a huge relief that its nothing major to get the engine going.
Spending the day today cleaning the head and getting here ready. ill get the valves out tomorrow and start lapping them. just gotta order the headgasket and head bolts so i can hopefully get her back together next weekend.
Old 04-10-2011, 06:10 PM   #87
Chris916
Chris916's Avatar
A bit of an update. Did some cleaning and removed the valves:
Before:
After:
Cleaned the bottom of the valves. there was quite a bit of build up on the exhaust side.
Cam trays:
And everything nice and shiny!
Then removed the valves. VERY time consuming.
Now i have to clean and lap the valves and put it all back together!
Old 04-10-2011, 07:26 PM   #88
Aero
Aero's Avatar
Lookin' good man! Just don't let Shawn talk you into doing an over-bore. Best get that head back on before you go nuts!
1996 328is Track Toy
2005 RSX Daily Driver
My Youtube Channel
Aero is offline   Reply With Quote
Old 04-10-2011, 07:59 PM   #89
Chris916
Chris916's Avatar
haha im not getting sucked into modding this engine!
Just ordered head bolts and a complete head gasket kit, so the goal is to have it all back together next weekend.
Old 04-11-2011, 06:12 PM   #90
Chris916
Chris916's Avatar
Cleaned all of the valves tonight
Before:
After:
I will start lapping them tomorrow. Still hoping to have it all back together this weekend!
