Welcome to!
Old 01-21-2011, 11:12 AM   #1
Complete power failure / Electronics Issue
I've been having some (electronics) problems with my 2007 328i Cabriolet.
Occasionally the ABS light with (!) comes on in the cluster along with a few other lights and I will lose all sound from the radio, no Aux, no Bluetooth etc.
I took it to the dealer in December to fix and they recode the system.
Yesterday I was driving and the cluster lit up like a Christmas tree again with all the lights mentioned above. I stopped, shut the car off and when I tried turning the car back on, I could not ... TOTAL LOSS OF POWER. Key would not come out of ignition, no lights for hazards etc. I had to get it towed to the dealer, but while the car is on the tow going to dealer (maybe about half hour later and about 500 metres) the headlights came on (remember key was still in ignition). So we stopped and checked what was going it. Tried starting it and it started fine, however, all the electronics (radio, time etc) were 'zeroed' ( _ _ :_ _). It's as if the battery was disconnected or something.
Has anyone experienced this sorta thing or know what could be the issue? Is it just something simple as the battery leads were loose or something? Or am looking at something major?
The good news is it's still under warranty until July.
Thanks in advance.
noeddeon is offline   Reply With Quote
Old 01-21-2011, 12:07 PM   #2
Tortures BMWs.
sparkybp's Avatar
In the trunk, on the positive cable going to your battery there is sort of a "safety disconnect" which is normally meant to pop out in case of an accident so that you don't have electricity hovering around gas spills and what not. sometimes it get knocked loose so you can check by pulling back and forth on the positive battery cable lightly.
Good discounts on all OEM and good quality aftermarket BMW parts. 519-498-9660.
Old 01-21-2011, 12:40 PM   #3
Your opinion is to long
Blades's Avatar
last time i had something like that the alternator went in my car or was slipping (bad belt)
-=[ BL/\DES ]=-
Old 01-21-2011, 03:29 PM   #4
Autobahn East
Possibly failure of the ELV with no terminal 15 activation, quite common on the E90 I see quite a few of these issues.
The IBS may cause the same issue.
Old 03-02-2011, 07:55 PM   #5
BimmerboyPH's Avatar
Check the main power supply going to the fuse box behind the glove box. Check its connection and make sure its not burnt or shorting.
88 325is- written off
89 735i 5 spd- traded
89 325is m50 swap- sold
92 325is- sold
97 328is- sold
00 Land Rover Disco- sold
07 328i- sold
84 325e- track car, in progress........ SOLD!
87 325is- FOR SALE
98 328is- Current Daily
BimmerboyPH is offline   Reply With Quote
