02-03-2011, 03:24 PM
is a pimp
Car: E46, E36
Oil light randomness?
I got my oil done maybe 3-4 weeks ago...
Note though, about 6-8 months ago i got my vanos fully done from dr vanos, but to this day i still dont know the guy doing it put everything correctly, as from time to time the car will start a bit odd..
anyways since that oil change... every now and then when i start the car, the oil lamp will turn on (yellow) and stay on for 15 seconds and off it will go...
wtf?
02-03-2011, 03:35 PM
Car: 325IS 87-325IC 89-IC
Don't worry bout it; do you have sufficient oil pressure? car performs normally? then I wouldn't give it much concern until your vanos craps out and then take it back to the doc.
maybe it's just the oil pressure switch. could be when he redid the vanos may have touched something by mistake..Keep in mind it is pretty cold out so the pressure takes a bit of time to build up.
02-03-2011, 03:48 PM
Addict
Car: M5
Faulty oil level sensor. Very common E46 problem. Mine has been doing this since I've owned it but I'm too lazy to change out the sensor. That, and it's ~$200 for that stupid part.
Imola Red / Imola Red ///M5
E60 SSK, Dice iPod, Illuminated ZHP knob, GT Custom Exhaust, BCR Coilovers
Past:
'01 330Ci Titanium Silver on Coral Red
'96 328i Jet Black on Black
02-03-2011, 03:51 PM
Car: MK6 GTi
if it were oil pressure, the light would be red, not yellow. Its your oil level sensor as Anuk said... make sure your oil actually isn't low though.
02-03-2011, 03:59 PM
Car: BMW 323ci, 350z
I had the same problem and as they said its your oil level sensor, nothing to worry about.
INTERLAGOS E36
02-03-2011, 04:06 PM
is a pimp
Car: E46, E36
ok cool thanks, oil can't be low i just got it changed
thanks guys
02-03-2011, 05:41 PM
Stance is Gay.
Car: '06 325i
thanks guys
E36's don't even have oil level sensors
Unless you're talking about your e46?
02-03-2011, 06:01 PM
is a pimp
Car: E46, E36
E46, the E36 has been stored away
02-03-2011, 06:29 PM
Over 9 F**KING THOUSAND!!
Car: '91 325iS | '96 332i
Check the oil level first. Could actually be low. Don't assume that because you just had an oil change that it's topped up.
02-04-2011, 06:15 PM
#10
wouldu like some tinfoil?
Car: E36-M42, ej22t
Rear main seal ?  hope not
02-05-2011, 11:01 PM
#11
Car: E46 M-Technik
I love when non E46 owners try to guess the problem, lol.
Yellow oil light stays on for 10-15 sec after start up = faulty oil sensor. New one costs around $150
Yellow light at shut off = you actually are low on oil, not significant, but low. It could also be a possibility that you havent warmed up your oil before shut off and it hasnt come back down fast enough.
Yellow light while driving = you're low on oil. If it comes up when driving, means you're burning/loosing oil.
Red oil light when engine is on = low or no oil pressure. Oil pressure sensor is SEPARATE from oil level sensor just so you know.
02-06-2011, 01:43 AM
#12
Car: E90 325i
Mine just started doing it as well...right after my last oil change...not an issue...
02-06-2011, 08:04 AM
#13
Hey, I'm just learning like everyone else.. thanks. :-)
02-06-2011, 01:16 PM
#14
Car: 330
Rocco replaced my oil sensor at the last oil change. Its a two minute job and I think it was around 100 or maybe even less. Pretty useful thing to have working properly in my opinion.
...VLAD...
02-06-2011, 01:18 PM
#15
Car: 87,325IS - E36 M3
dbworld4k is 100%
ever e46 will need to change this sensor sometime in it's life lol
