Old 01-24-2011, 10:25 PM   #1
d.maczko
Registered User
Cool unloading turbo m20 parts
I am planning an engine swap so all of my m20 turbo stuff will be for sale.
I have a running turbo car, so everything you could imagine for a running car.
ebay manifold modified for 38mm external waste gate
ebay intercooler 24x12x3
3" downpipe with provision for waste gate to dump
holset h1e 18^cm3
-4an feed line, -10an drain line
welded oil pan for turbo drain
fittings for oil feed from pressure port on block
black powder coated charge piping and couplers
HKS ssqv bov
MS 2.2 with waste spark, GM coils, MSD wires
boost, oil press, water temp, egt pro sport gauges
.140 MLS headgasket
metric blue head bolts
would like to sell as a whole but will part out most likely
all parts are still on the car but will take apart as stuff sells
dont be afraid to pm me to ask anything
d.maczko is offline   Reply With Quote
Old 01-26-2011, 03:23 PM   #2
d.maczko
Registered User
ebay manifold modified for 38mm external waste gate. 350
ebay intercooler 18x12x3 80
3" downpipe with provision for waste gate to dump 100
holset h1e 18^cm3 300
-4an feed line, -10an drain line 80
welded oil pan for turbo drain 250
fittings for oil feed from pressure port on block 10
black powder coated charge piping and couplers 100
HKS ssqv bov 25
MS 2.2 with waste spark, GM coils, MSD wires 300
boost, oil press, water temp, egt pro sport gauges 120
.140 MLS headgasket 100
metric blue head bolts 40
edit: will be adding more parts later today
I should mention the MS is a plug and play unit made by rs4pro
all you need to do is wire up the IAT
few other parts
B&M oil cooler, SS lines and nec fittings to use with factory oil filter housing 250
adjustable FPR, bolts into stock fuel rail, looks identical to stock unit. 50
Old 01-26-2011, 03:24 PM   #3
d.maczko
Registered User
Old 01-26-2011, 05:01 PM   #4
thats a good deal for a PnP MS with coils and wires!
Old 01-27-2011, 03:43 AM   #5
Another BM
dibs on M.blues and M.S system
Another BM is offline   Reply With Quote
Old 01-27-2011, 12:00 PM   #6
canuckder
canuckder's Avatar
pm'ed for a few items also
canuckder is offline   Reply With Quote
Old 01-27-2011, 03:18 PM   #7
e30_kid89
The Afro-stig
e30_kid89's Avatar
I'd suggest getting ARP headstuds, unless you like changing the headgasket often
Old 01-27-2011, 03:43 PM   #8
NOTORIOUS VR
NOTORIOUS VR's Avatar
+1billion... On a boosted M20 nothing but a real headstuds should be even considered.
ARP & Raceware
Old 01-30-2011, 04:05 PM   #9
DR.ZED
Does the AFPR come with a gauge?
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 02-01-2011, 12:01 PM   #10
supernaught
supernaught's Avatar
how much for the whole?
Old 02-02-2011, 03:28 PM   #11
d.maczko
Registered User
Shoot me an offer on the whole setup and I'll get back to you
