12-09-2010, 08:23 AM
#196
Car: '08 M3, '97 328is
Alright so I got quite a bit done last night.
Made the oil cooler lines, mounted the oil cooler with Wills sweet brackets haha. Also got the motor back together 100%. Fresh oil, new filter, new fuel filter. Topped it up with some deionized water and a bit of coolant
Of course now it won't start...I'm double checked everything but can't seem to find the problem. I don't seem to hear the fuel pump either. Motor doesn't even crank.
I just remembered after getting home that the only change other than OBDI on the car was the clutch stop I put in. I'm hoping that's the problem. Since it's homemade and I've never adjusted it, the clutch pedal switch might not be working. Hopefully I can get this all sorted out today.
12-09-2010, 11:13 PM
#197
Alright I went to the shop tonight to get this stupid thing running and succeeded.
I gave Mike a call (from Stancefactory) since he's a BMW wiring genius. He explained how I had to bypass the EWS which I didn't think I needed to do. Then the car would crank but wasn't getting fuel.
Turned out when I changed the pumps and re-wired them, I got the positive and ground mixed up. So the pumped was operating, but backwards.
Rewired that, and it started perfectly. Runs great. Probably going to take it for a test drive tomorrow.
Also going to make my intake heat shield tomorrow. I make a DIY on that.
So it's almost there!
Whats left:
Install 3.73 LSD when it's done.
Change some of the rear end mounts and do front control arm mounts
Cage
Install seats and harnesses
New balljoints and Tie Rods
Then it's pretty much done!
12-09-2010, 11:15 PM
#198
Car: God's Chariot
Saaaaaaakkkkkkkkkkkk
12-09-2010, 11:35 PM
#199
TAKE IT TO THE TRACK
Car: E30, E39, E82
Congratulations man! Good show. Taking it to the Max meet tomorrow pm maybe??? If so, I might go to check it out, I'll be in the neighborhood working till 8-9ish?
BMW 325I E30 Chumpcar Race Car
BMW 135i Msport Daily/track toy
12-10-2010, 09:41 AM
#200
"Mint"
Car: '98 328is + '93 525i
lol he can't exactly drive it that far
Congrats man, let me know if you're in the shop around 7:30-8, I wanna hear her.
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
1988 Mercedes Benz 190E 2.3-8V - sold
12-10-2010, 08:21 PM
#201
Made me a sweet heat shield today! Entire intake cost: $10
Cardboard template:
Cut and bent:
Test Fit:
Added some weatherstripping to seal and also made a hole for the oil lines. Used a 3 1/4" hole saw for the intake:
Painted and done!
12-10-2010, 08:41 PM
#202
Ahhhh the office:
12-10-2010, 10:12 PM
#203
Vtec just kicked in
Car: 99 S52
you are still running an oem rad? :/
did you weld in reinforcement plates for the rear/front subframe?
nice progress.
like the euro expansion.
-||Old Crayons||-
12-10-2010, 10:28 PM
#204
nice progress.
Whats wrong with OEM rads? I plan to get an aluminum rad in the future but it isn't necessary.
The front cross member will get plates later on, the rear subframe doesn't need anything since it's an M3.
12-11-2010, 12:57 AM
#205
Car: 91 318is,93 325is...
Rear sway bar mount reinforcemt tabs?
12-11-2010, 06:05 AM
#206
I don't think it necessary personally. I ran a massive UUC rear bar for two years on my 328 with no signs of damage.
So with a stock swaybar in the back of this car, I dont think there will ever be an issue. Especially when the springs and rear end will be stiff enough that there won't be much pressure on the bar in the first place. Once you get the rear ends on these cars tightened up, the swaybar pretty much becomes obsolete.
12-11-2010, 12:35 PM
#207
Car: E30 328i, E21 320i
From an aesthetics standpoint black is a great colour for the intake heat shield... from a thermodynamics stand point it's a terrible colour lol. I would have covered the side facing the engine with heat reflective tape.
12-11-2010, 12:47 PM
#208
Well in my opinion, it's just an intake heatshield. Not rocket science.
Sure I could buy some fancy tape for it, but is it going to make a difference? No.
12-11-2010, 01:34 PM
#209
It's not too fancy, you can by a 2" wide x 30' long roll for $5 at home depot, less than the cost of a can of spray paint. It was just a suggestion.
12-11-2010, 01:43 PM
#210
Car: 325i, 318is
looks good man, glad to see it coming together.
4cyl autotragic woes...
Thread Tools |
Display Modes |
