Old 11-18-2010, 08:56 PM   #166
Stance is Gay.
I got my coolant temp sender all sorted out tonight.
First I modified the coolant port that runs to the throttle body from the head. Cut the top off, then drilled and tapped to 1/8 NPT.
Voila, will screw right back into the head!
Old 11-19-2010, 02:46 PM   #167
Dr. Flyview
Formerly Flav_cool
Dr. Flyview's Avatar
Nice engineering bro! Will post pics of our RTAB tool lol.
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
sold
Old 11-22-2010, 10:32 AM   #168
iverson03tj
Ok thanks guys I ordered the VDO gauges and sensors.
@Doogee - With the oil distribution block... did you buy the (2) 1/8 NPT adapters?
@ sb 600 - Ok cool i just found one locally, for a used one..
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ240889224
I hope he hasnt sold it yet!!
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
'95 Acura Legend Type II
'97 Euro Estroil E36 M3 Vert
Old 11-26-2010, 06:41 PM   #169
Stance is Gay.
Yes sir
Old 11-28-2010, 09:13 PM   #170
Stance is Gay.
Passenger seat acquired.
Can't turn down $150 for a Brand new Recaro SPG
Old 11-29-2010, 10:22 AM   #171
Royksopp
Royksopp's Avatar
thats Legit!
Royksopp is offline   Reply With Quote
Old 11-29-2010, 11:09 PM   #172
Stance is Gay.
Tried out some rubber trim from good ol Crappy tire for the sharp edges on the door. Worked out nicely.
Also did the EVAP delete:
Sweet nascar battery adds 40whp:
Old 11-30-2010, 09:14 AM   #173
Dr. Flyview
Formerly Flav_cool
Haha that's the same battery I have...with the terminals on the wrong side. What the hell is an EVAP?
sold
Old 12-01-2010, 06:19 PM   #174
Stance is Gay.
In general, the EVAP system keeps fuel (vapor) from escaping into the environment.
Bimmerworld order finally arrived!
Check out the professional product shots I took lol. Looks like I have some work to do tomorrow!
Oil Distribution block with 1/8 NPT adapters.
Coolant block off for the back of the head:
And a 10.9 grade diff bolt
Old 12-02-2010, 06:36 PM   #175
Stance is Gay.
Coolant block off installed:
Oil Distribution block installed with oil temp sender and stock oil pressure sensor. Use a stainless braided line to remote mount the Oil pressure sender.
Coolant temp sender also installed in head.
Pressure sender mounted:
Tomorrow I'll run the wiring for the gauges.
Oil cooler should arrive early next week. Then it's motor starting time!
Old 12-02-2010, 09:04 PM   #176
3x Beemer
nice! where did you get the stainless line made? I'm in the middle of sorting out my guage install as well. going to drill and tap the banjo bolt but would still like to mount it remotely. I was going to check out some hydraulic places tomorrow..let me know
03 AW on LSB M3 coupe, BMW motorsport 4.10 Diff, AA Exhaust, OEM CSL rims, Aero Res, TMS subframe, powerflex bshgs, Macht Schnell, Vorsteiner diffuser, TMS steel lines etc..
Complete Comp Pkg Upgrade
98 328is hamann HM2,3.23 diff, ZKW headlights, HID fogs, M3 front, sides, rear and mirrors.UUC rsc36 exhaust, fk coilovers, X brace,UUC tran mounts. Spal fan, Mishimoto rad, AKG rtab, Pweflex CAB. Rogue RSM,SS clutch line, m3 subframe plates, pf bushs
09 F250, 2012 Honda CRV winterbeater
3x Beemer is offline   Reply With Quote
Old 12-03-2010, 04:42 PM   #177
Stance is Gay.
I got it from some "Hot Rod" shop in Cambridge. I'll let you know if I remember the name of the place. It's just a 36" -3 line.
By the way, I have a spare oil block I'm looking to sell if you're interested.
Old 12-04-2010, 02:22 AM   #178
Stance is Gay.
Had a talk with the guy who's going to be doing my cage.
Set to be done around New Years. Time to start saving :o
Rough Mockup:
Still haven't decided on the side protection.
Old 12-04-2010, 02:31 AM   #179
BMXWill
BMXWill's Avatar
^When did you switch from an M3 to a jeep? Just kidding!
BMXWill is offline   Reply With Quote
Old 12-04-2010, 02:34 AM   #180
Stance is Gay.
I need to be protected during an off road rollover. Wouldn't want to smash my head off a rock or tree stump
Just wait until I get these badboys on!
