11-08-2010, 02:18 AM
#151
Stance is Gay.
Car: '06 325i
Nice new Sparco, thanks to Rudy!
11-08-2010, 08:25 AM
#152
TAKE IT TO THE TRACK
Car: F30, E30
gerk!
BMW F30 335i M-sport - SerpaBMW Company Art car
BMW 325I E30 Track Rat
VW JETTA 1.8T WAGON Family Hauler (sold)
HONDA ODYSSEY 2nd Family Hauler (sold)
11-08-2010, 01:41 PM
#153
Stance is Gay.
Car: '06 325i
Originally Posted by dble Trouble
gerk!
Rudy is the jerk who got the amazing deal! Haha
11-08-2010, 01:42 PM
#154
Car: 91 318is,93 325is...
if your planning to use the car at track schools, they usually require matching seats and harnesses for both driver and instructor.... I see 2 in the pic.
11-08-2010, 01:43 PM
#155
Car: God's Chariot
He is buying a different seat for the passenger.
11-11-2010, 03:40 PM
#156
Stance is Gay.
Car: '06 325i
More goodies have arrived. Oil line and fittings, Gauges and senders.
Got a great deal on all this from Summit Racing. Can't go wrong at $25 per gauge!
There was a little bag with stickers and whatnot in the box. But look at the other sweet Freebie!!! Hahaha:
So just waiting on some little things from Bimmerworld and the Oil Cooler. Engine should be running again next week.
11-11-2010, 06:12 PM
#157
Car: M3,328is,F250, CRV
nice stuff. whats planned for the oil distribution block?
this is my fav design so far
http://forums.bimmerforums.com/forum....php?t=1507107
03 AW on LSB M3 coupe, BMW motorsport 4.10 Diff, AA Exhaust, OEM CSL rims, Aero Res, TMS subframe, powerflex bshgs, Macht Schnell, Vorsteiner diffuser, TMS steel lines etc..
Complete Comp Pkg Upgrade
98 328is hamann HM2,3.23 diff, ZKW headlights, HID fogs, M3 front, sides, rear and mirrors.UUC rsc36 exhaust, fk coilovers, X brace,UUC tran mounts. Spal fan, Mishimoto rad, AKG rtab, Pweflex CAB. Rogue RSM,SS clutch line, m3 subframe plates, pf bushs
09 F250, 2012 Honda CRV winterbeater
11-11-2010, 06:17 PM
#158
Stance is Gay.
Car: '06 325i
Originally Posted by 3x Beemer
That's a decent design. I'm using Bimmerworlds. It's much simpler.
Also isn't a very good place to mount the Oil Pressure sender.
11-11-2010, 06:38 PM
#159
yea now that i read through all of the comments under the diy I can see where other designs are better, i guess i was just impressed the guy came up with that on his own. however his microphone jack and computer monitor connection are genious!
11-16-2010, 10:07 PM
#160
Stance is Gay.
Car: '06 325i
Today I got the gauges mounted. Not wired yet though.
Drilled the holes with a 2" holesaw on a drill:
Et Voila:
I also ran into some yellow paint at the store and thought it would match Dakar perfectly. What do you know it does. Should work perfectly for painting the interior!
11-16-2010, 10:10 PM
#161
Car: 325i, 318is
the razor is to shave paint to save weight.
cars coming along nicely man, she'll be really nice when its done, done properly at that so nothing to worry about, no point in half assing stuff and worrying about it later
...now hurry up and put a cage in that thing!
4cyl autotragic woes...
11-17-2010, 10:43 PM
#162
Car: e36 328is S/C'd
Im pretty noodish when it comes to mechanics, but how hard would you saying installing a water temp, oil temp and oil pres gauge be, wth sending units, and where do you place all the units... is there alot of modification needed to be do also i got a ait to fuel mix gauge but i need the wideband sensor... where would be the cheapes to buy one?
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
'95 Acura Legend Type II
'97 Euro Estroil E36 M3 Vert
11-18-2010, 12:18 AM
#163
Stance is Gay.
Car: '06 325i
Well I'll state my case and where I'm putting the sending units.
The Oil Temp and Pressure senders will be located in an Oil Distribution block from bimmerworld. It connects to the back of my Oil Filter housing from the Euro M3 which allows me to run a cooler as well.
But you can use the same oil distribution block with a US style filter housing as well.
As for the water temp. I'm not 100% on how I'm going to do this. I brought home some plugs for the head where the lines run to the throttle body. Going to make an attempt at drilling those out and tapping them to 1/8-27 NPT which is the correct thread for the VDO and most aftermarket senders.
And I don't know anything about Air/Fuel gauges
11-18-2010, 12:23 AM
#164
Stance is Gay.
Car: '06 325i
Finished all the wiring for the gauges today:
And finished the door stripping and painted:
11-18-2010, 10:29 AM
#165
Car: e36 M52 330i
I bought the M50 block off plate from bimmerworld, and tapped into that. It bolts up to the back of the block to replace the flange where the coolant line went to the heater core. Works like a charm!
Another option that I've heard of is tapping into the aluminium thermostat housing.
Looks good!
iverson - i just picked up a wideband O2 sensor with an AFR gauge. I got the Innovate LC1 system on ebay. I think it cost around $180. Apparently you just need to splice into the wire from the ECU, and the gauge plugs right in. Haven't done it yet though... that will happen later this winter when the new engine is put it.
