Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 11-08-2010, 03:18 AM   #151
Nice new Sparco, thanks to Rudy!
Old 11-08-2010, 09:25 AM   #152
dble Trouble
TAKE IT TO THE TRACK
dble Trouble's Avatar
gerk!
BMW 325I E30 Chumpcar Race Car
BMW 540iT M-Sport (New Family Hauler)
BMW 135i Msport Daily/track toy
dble Trouble is offline   Reply With Quote
Old 11-08-2010, 02:41 PM   #153
Originally Posted by dble Trouble View Post
gerk!
Rudy is the jerk who got the amazing deal! Haha
Old 11-08-2010, 02:42 PM   #154
richie_s999
if your planning to use the car at track schools, they usually require matching seats and harnesses for both driver and instructor.... I see 2 in the pic.
Old 11-08-2010, 02:43 PM   #155
He is buying a different seat for the passenger.
Old 11-11-2010, 04:40 PM   #156
More goodies have arrived. Oil line and fittings, Gauges and senders.
Got a great deal on all this from Summit Racing. Can't go wrong at $25 per gauge!
There was a little bag with stickers and whatnot in the box. But look at the other sweet Freebie!!! Hahaha:
So just waiting on some little things from Bimmerworld and the Oil Cooler. Engine should be running again next week.
Old 11-11-2010, 07:12 PM   #157
3x Beemer
nice stuff. whats planned for the oil distribution block?
this is my fav design so far
http://forums.bimmerforums.com/forum....php?t=1507107
17 Audi A4 S Line
03 AW on LSB M3 coupe, BMW motorsport 4.10 Diff, AA Exhaust, OEM CSL rims, Aero Res, TMS subframe, powerflex bshgs, Macht Schnell, Vorsteiner diffuser, TMS steel lines etc.. Sold
Complete Comp Pkg Upgrade
2012 Honda CRV winterbeater
3x Beemer is offline   Reply With Quote
Old 11-11-2010, 07:17 PM   #158
That's a decent design. I'm using Bimmerworlds. It's much simpler.
Also isn't a very good place to mount the Oil Pressure sender.
Old 11-11-2010, 07:38 PM   #159
3x Beemer
yea now that i read through all of the comments under the diy I can see where other designs are better, i guess i was just impressed the guy came up with that on his own. however his microphone jack and computer monitor connection are genious!
17 Audi A4 S Line
Old 11-16-2010, 11:07 PM   #160
Today I got the gauges mounted. Not wired yet though.
Drilled the holes with a 2" holesaw on a drill:
Et Voila:
I also ran into some yellow paint at the store and thought it would match Dakar perfectly. What do you know it does. Should work perfectly for painting the interior!
Old 11-16-2010, 11:10 PM   #161
tg07lq
the razor is to shave paint to save weight.
cars coming along nicely man, she'll be really nice when its done, done properly at that so nothing to worry about, no point in half assing stuff and worrying about it later
...now hurry up and put a cage in that thing!
4cyl autotragic woes...
Old 11-17-2010, 11:43 PM   #162
iverson03tj
iverson03tj's Avatar
Im pretty noodish when it comes to mechanics, but how hard would you saying installing a water temp, oil temp and oil pres gauge be, wth sending units, and where do you place all the units... is there alot of modification needed to be do also i got a ait to fuel mix gauge but i need the wideband sensor... where would be the cheapes to buy one?
PREVIOUS CARS
Old 11-18-2010, 01:18 AM   #163
Well I'll state my case and where I'm putting the sending units.
The Oil Temp and Pressure senders will be located in an Oil Distribution block from bimmerworld. It connects to the back of my Oil Filter housing from the Euro M3 which allows me to run a cooler as well.
But you can use the same oil distribution block with a US style filter housing as well.
As for the water temp. I'm not 100% on how I'm going to do this. I brought home some plugs for the head where the lines run to the throttle body. Going to make an attempt at drilling those out and tapping them to 1/8-27 NPT which is the correct thread for the VDO and most aftermarket senders.
And I don't know anything about Air/Fuel gauges
Old 11-18-2010, 01:23 AM   #164
Finished all the wiring for the gauges today:
And finished the door stripping and painted:
Old 11-18-2010, 11:29 AM   #165
I bought the M50 block off plate from bimmerworld, and tapped into that. It bolts up to the back of the block to replace the flange where the coolant line went to the heater core. Works like a charm!
Another option that I've heard of is tapping into the aluminium thermostat housing.
Looks good!
iverson - i just picked up a wideband O2 sensor with an AFR gauge. I got the Innovate LC1 system on ebay. I think it cost around $180. Apparently you just need to splice into the wire from the ECU, and the gauge plugs right in. Haven't done it yet though... that will happen later this winter when the new engine is put it.
