Old 10-21-2010, 04:44 AM   #1
scotty328ci
Arrow power steering VIBRATION
hey all
came home from work tonight , car had been driving fine for the hole 30 min it takes me to get home , but when i pulled to a 4 way stop my steering wheel and column started to vibrate like crazy when i turned the wheels from left to right and made a constant loud sound from the front
would i just be low on power steering fluid or has something major gone about. it was raining on the way home but don't think that has anything to do with this.
car is all stock, no mods what so ever, no engine check light nothing
thanks for the help
scotty328ci is offline   Reply With Quote
Old 10-21-2010, 11:37 AM   #2
uzi577
RUNING BOOST
uzi577's Avatar
Start from checking fluid, belt , suspension and steering links! Did any (cel)codes came on? report back and will try to help!!!!!!
uzi577 is offline   Reply With Quote
Old 10-21-2010, 12:35 PM   #3
scotty328ci
hey
it has tons of fluid , no codes came on at all , took it up to my local garage and he said its def the pump , but it almost sounds to him as if there is broken spring inside and the fluid isn't pumped through right!
Old 10-21-2010, 10:05 PM   #4
uzi577
RUNING BOOST
uzi577's Avatar
what is the mileage on the car?
Give Eurostyle a call he will hook you up with used one, if you want new then Marenello in the place for the part.
Old 10-21-2010, 10:33 PM   #5
RMPMOTORS
RMPMOTORS's Avatar
We sell new pumps and install!
Give us a call for a quote!
www.RMPMOTORS.com
www.Facebook.com/RMPMotors
Old 10-24-2010, 05:43 PM   #6
hamant
its a relatively simple DIY if you want to..
hamant is offline   Reply With Quote
Old 10-26-2010, 12:58 AM   #7
fuufuu
fuufuu's Avatar
Got the same problem today too. Gonna order the part tomorrow fix it during the weekend hopefully. Did you fix it yet?
fuufuu is offline   Reply With Quote
Old 11-04-2010, 05:32 PM   #8
scotty328ci
i placed the order for the part!! but had to wait 2-4 business days for it to come in , in the mean time took it apart to see if anything could be a quick fix internally ,
right after that the noise completely stopped and has not come back since then
Old 11-04-2010, 07:33 PM   #9
fuufuu
fuufuu's Avatar
ahh well my car continued to do make the noise and vibration for 3 days, jacked it up removed the pump and hose (was a mission), bought a used pump (LUK LF-30 instead of the stock 20) and new high pressure hose. In total spent 150 and 140 sooo 190-ish...cheaper than any garage and I spent about 3 hours on it (loosening the belts without removing the rad fan is why it took so long...).
About to install the hose after dinner...I got about 3 scrap hoses and none of then were the one I needed regardless if it looked right, so I bought a new one. it better be it.
Old 11-04-2010, 08:12 PM   #10
fuufuu
fuufuu's Avatar
and it works sweet sailing till my next problem lol
