Old 11-01-2010, 06:56 AM   #136
Currently waiting on:
Bimmerworld Oil Distribution Block
Bimmerworld S50/S54 Oil Diverter Valve (to replace the stock thermostat)
Oil Cooler, lines, fittings etc
VDO Gauges and Senders (Oil Temp, Oil Pressure, Water Temp)
Old 11-01-2010, 10:21 AM   #137
This thread needs more:
Old 11-01-2010, 10:21 AM   #138
Lmao
Old 11-02-2010, 09:32 PM   #139
Today I mounted the coolant tank. Got the special brackets to mount to the chassis. They're supposed to be welded in, but since I don't have access to a welder, I use rivets and bolts instead. Rock solid.
I had to move the battery post back to the OBDII position since the tank is in the way. So I also extended the OBDI wiring harness to reach.
Old 11-02-2010, 09:43 PM   #140
dble Trouble
TAKE IT TO THE TRACK
dble Trouble's Avatar
Kurt after seeing how awesome your 328 was on the track, this thing will be a monster! I'm looking forward to seeing you in this next year. I really like the quality of the parts you are using, you're not "cheaping out" just because. Good show!
BMW 325I E30 Chumpcar Race Car
BMW 135i Msport Daily/track toy
Old 11-02-2010, 09:48 PM   #141
Yeah it should be a real fun toy!
I learned not to cheap out on these kind of things when me and a friend built up an S14 240sx two years ago. Chinese parts. Engine was done 15 minutes into it's first track day due to a pretty massive cooling system failure.
So while it's more expensive, I have a lot of time to finish and a lot of saving to do. But in the end, should be a bulletproof track car.
Old 11-03-2010, 08:51 AM   #142
I like this switch layout:
Old 11-03-2010, 09:28 AM   #143
Fern3
formerly e36.M52B25
Fern3's Avatar
hahahaha
| M54B30/6MT Swap | KW V2 Coilovers |3.46 Diff |
|Genuine 19x8.5/9.5 Style 172M Wheels|
Fern3 is offline   Reply With Quote
Old 11-04-2010, 12:05 AM   #144
Todays work included changing out both Fuel Senders and the 95+ style siphon out for the Pre-95 style.
The reason is because the car will starve for fuel on hard right turns. So I either had the option to buy a Bimmerworld kit which includes two fuel pumps, or just convert to the 92 style which is just a better siphon system.
I don't know how effective this will be compared to the Bimmerworld kit, but we'll see in the spring!
Old 11-04-2010, 08:27 AM   #145
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
You've felt the 328 starve for fuel on hard right turns?
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 11-04-2010, 08:50 AM   #146
Yup it's actually undriveable once the tank drops below half.
Old 11-04-2010, 10:20 AM   #147
rider-.
^^ yup, annoying as balls!
I found a solution for e46 non m's which have the same problem, I just havent got around to it yet. Not sure if it will work for e36 tho, but it is a cheap option to give a try.
http://www.e46fanatics.com/forum/sho...d.php?t=687864
Old 11-04-2010, 02:20 PM   #148
richie_s999
looks good, but rivits could shear with vibration over time, could try the threaded inserts and bolts kit from PA. Looks like it may hamper access to the computer
Old 11-04-2010, 03:45 PM   #149
I'm pretty confident they aren't going anywhere. Even if they did manage to break off, it's not like the tank is going anywhere. You could literally rest it in there without mounts haha. Also it isn't a solid mount, there is plenty of play between the bracket and tank to absorb anything like that.
It isn't in the way of the computer any more than the air pump was. The tank pops off the mounts for more access anyway.
Old 11-04-2010, 03:54 PM   #150
There isn't any tension on those brackets, so why on earth would they break? Rivets main purpose is to hold shear loads anyways. If planes are riveted together, pretty sure it can hold an expansion tank with less than a liter of fluid.
