Old 11-01-2010, 07:03 PM   #1
Trekz
e36 Stalling While Driving! Need Help!
My car just started stalling while driving it will die then just start itself back up. Mostly Happens over bumps! Coils are good, fuel pressure is good, plugs are good, no vacuum leaks, o2 was changed in the beginning of summer, Ground from block to body was corroded, cleaned it up real good, same thing! It happens intermittently, some times i can drive for good 45 min and its fine and other times it will happen like 3 times in a row. Car idles fine and doesn't stall, no codes!
Any ideas and what else to check?
Its a 94 325.
Edit: Compression test is also good!
