Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 10-13-2010, 11:48 AM   #1
sonny
sonny's Avatar
Question e46 Subframe Cracking Help
Does anyone have pics of a cracked subframe. I'm curious to see where and what exactly to look for if trying to find it myself.
I've peeked under the car and came across these holes from cracking and rust..as seen in the picture below.. is this the subframe problem everyone is talking about?
Help would be appreciated.
sonny is offline   Reply With Quote
Old 10-13-2010, 07:29 PM   #2
xlr8nbimbo
There are a number of videos on youtube. Here's one to get you started. Check out the others that link from it. http://www.youtube.com/watch?v=hoIUcCMyUHg
xlr8nbimbo is offline   Reply With Quote
Old 10-13-2010, 08:54 PM   #3
B6T
The 'cracks' you see in your picture are stamped into the formed steel piece before it is welded to the bottom half.
Summer: BMW 135i M-Sport
Winter: 2004 Audi A4 Ultrasport 2.7tt
Year round: 6 cylinders, two turbos, and 6 speeds.
B6T is offline   Reply With Quote
Old 10-14-2010, 04:23 PM   #4
andrew.k
Top Gear Professional
andrew.k's Avatar
That has absolutely nothing to do with with BMW E36/E46 sub frame cracking issues. Its simply a weld BMW created. We all have it.
This is a crack near the lower sub-frame mounting point.
This is a cracked sub-frame
Driver side rear lower enforcement
Drivers side front enforcement
Hope this helped.
330i | M Technik | BBS 197 | 3D Studie | H&R
andrew.k is offline   Reply With Quote
Old 10-14-2010, 09:21 PM   #5
Blocked_Out
Banned
OMG, the number of uneducated/uninformed people bugs the fvck out of me.
When one says E46 rear subframe damage they actually refer to a cracked/ripped sub-floor. ( dont know what the 3rd 4th and 5th pictures posted are, but they sure dont look like E46 subframe ). ANyway, to see if you have a any damage you need to look at the 4 mounting points. The subframe (diff carrier) bolts to the subfloor of the car with 4 point. The subfloor cracks and may even rip out. Most, if not all call this "subframe failure" when actually its the subfloor(I've yet to see or EVEN hear of an actual subframe on E46 being bad or breaking, except from rusting away, but that irrelevant).
This picture will show the area to inspect more clearly.
Most common failure point is the driver side rear mount.
quadexhaust
Blocked_Out is offline   Reply With Quote
Old 10-15-2010, 12:59 AM   #6
andrew.k
andrew.k's Avatar
"( dont know what the 3rd 4th and 5th pictures posted are, but they sure dont look like E46 subframe )."
They sure do look like an E46 sub-frame because they are, if you looked a little more closely. The gas tank has been dropped and everything has been removed.
Here's a picture of the reenforcement plates primed and painted.
Everything installed and aligned
Old 10-15-2010, 12:16 PM   #7
B6T
FWIW, a service advisor at the BMW dealership told me that BMW traced the failure back to an improper material usage by the company who supplied the discrepant stampings to BMW. They were also able to determine what cars those parts made it on to, so there is a certain range of VIN numbers affected by this problem. We could of course disprove this by taking a tally of the production dates of cars affected, as well as the serial numbers.
I was under the impression that OEMs stamp, weld, construct, etc. the entire unibody and don't sub-out those components. I guess BMW does things a bit different.
And the guy above is right, it isn't at all a "subframe" failure. It wouldn't be that big of a deal if it were a subframe issue. Instead, it's an issue with the unibody, the "part" that everything on the car bolts to. Not very easy to re-and-re...
Old 10-27-2010, 09:46 PM   #8
sonny
sonny's Avatar
Where have you guys been taking your cars for subframe or unibody repairs?
Uninformed, uneducated..however you want to put it, the title of this thread includes the word "help".
Old 10-27-2010, 09:56 PM   #9
RMPMOTORS
RMPMOTORS's Avatar
We repair and install re-enforcement kits on the E46 on a weekly basis!
Rocco
Eibach-Koni-Bilstein-H&R-Powerflex-KW Suspension-OEM Parts+ MORE
EUROPEAN AUTO SERVICE & PERFORMANCE
www.RMPMOTORS.com
www.Facebook.com/RMPMotors
RMPMOTORS is offline   Reply With Quote
Old 10-27-2010, 11:01 PM   #10
parm
Scarboro Mazda S&L
parm's Avatar
My neighbour took his e46 to the dealer and they are fixing it no cost to him, he is just with out a car for a week!
parm is offline   Reply With Quote
Old 10-27-2010, 11:06 PM   #11
RMPMOTORS
RMPMOTORS's Avatar
You are correct, the dealer will fix some of the torn cars, they will not be re-enforced or any stronger then it was originally.
I just give an option that will make your car stronger then it originally was, and you get your car back in 1 day!
www.RMPMOTORS.com
Old 10-28-2010, 02:01 AM   #12
Too bad they dont build them like they used to! You would have never seen this on a 5-10 year old E30!!! Too bad 25 years have taken a toll on them...
Old 10-28-2010, 02:10 AM   #13
lvan
lvan's Avatar
Send a message via MSN to lvan
+1 and I agree, but how come you went for the E46? Like why not Newer E36/E90?
lvan is offline   Reply With Quote
Old 10-30-2010, 11:43 AM   #14
Blocked_Out
Banned
I think because those are crap.
