Old 09-24-2010, 09:00 AM   #1
SamE30e
SamE30e's Avatar
FS: 91 318is M50 Swapped E30
Hey,
I'm selling my M50nv swapped E30. I did the swap a year and a half ago. I'm selling it because I need something newer for my commute to school and a change of scenery.
Body
450,000 on body (swapped clusters because of bad speedo and ODO gears (says 30x,xxx)
Replaced front fenders (flat black)
Replaced sunroof (Dark blue)
Replaced trunk lid
Minor rust on body, all repairable.
Underside is super clean and solid
Car would need a paint job and some body work.
Volvo front lip
iS rear spoiler.
Passenger door is dented pretty bad (Person before me rode a lamp post or something but is fixable and not very noticeable from 20 feet)
Engine
M50Nv
200,000km on the engine
Fresh rebuilt head.
ARP Head studs
Minor port on head
New valve stem seals
New valve guides
Head was hot tanked and cleaned
Always run synthetic since I've owned it
Every single gasket was changed when I did the swap and head rebuild.
New rear main seal
Engine doesn't drop one bit of any fluid
New cam sensor
New coolant temp sensor
Newer MAF
318is engine wiring covers
Dinan 91 octane ECU
14" E-fan, wired to stock wiring. (You can turn it on, or it comes on automatically)
80 degree T-stat (brand new with the head)
Top end rebuild has about 2000km on it, and when I say every gasket was changed, I mean EVERY gasket was changed.
Exhaust
Superspring replica stainless long tube headers
2.5" Stainless single mandrel bent piping
Vibrant Cat
18" stainless resonator
Vibrant 2.5" in/out Street power sleeper muffler
Brand new O2 sensor
Exhaust was done 2 weeks ago at JPG, cost me about 700$, I have the reciepts for it.
Engine pulls hard, I've been told that with 19lbs injectors and a Millar W.A.R tune it should make 200whp, but realistically 190whp is possible. (Which would put you in the 13's in an E30 and would be pretty quick but not overpowered). I have a set of 19lbs injectors I'll include. I had them in the car and it pulled like a mother, but I reset the ECU and had to put all the stock ones back in.
Transmission
Euro 323i M20 flywheel, lightened to 11lbs
M20 friction disk
Sachs pressure plate (I think it's a HD one, I bought it off someone who didn't know what it was, I never checked the part number, but it is pretty stiff and is impossible to slip)
New TOB and Pilot bearing with the swap
Z3 1.9 short shifter
Solid bushings on the shift carrier and all other bushings replaced
New CSB
4.10 LSD (Works well)
Suspension and Brakes
H&R Sport springs
Tokico HP struts (Fronts have maybe 5000km on them)
Ireland Engineering poly urethane rear subframe bushing
Sparco front upper strut bar (Red and beefy)
Has a newer steering rack that doesn't leak
Brembo blank rotors
PBR pads with lots of life left
Stainless steel and coated brake lines.
All new ball joints
Interior
Nardi leather wrapped wheel
Sparco shift knob
E30 sport interior with no real major flaws except some wear on the driver seat, but no rips.
Autometer AFR gauge (Narrow band, not very accurate but looks cool)
Has a deck in it, wired to the premium stereo with a 12" MTX sub and amp, but that would cost extra as I can use it in a new car. I would put a Panasonic MP3 deck with aux in if you didn't want it.
Sunroof was converted to Electric, but just needs to be wires
Oh, and super dooper rare (I've heard and been told) OEM black headliner.
Wheels and tires
The car comes with stock 14" weaves, 2 tires are shot.
Also comes with a set of 16x7.5 TSW Hockenheims with BRAND NEW (500km on them) Goodyear Eagle F1 gt's (Expensive and awesome tire) 215/40/16. Wheels are a FWD offset, so I have a set of T6061 aluminum 20mm front/15mm rear hubcentric spacers, that are fairly new.
Overall the car is mechanically solid, the only thing I think it needs is a Diff bushing (Which is a 20 minute job) and front LCAB's (Which I will include and possibly do before it's sold) and body work. I'm asking $4500, but am open to reasonable offers. If you're going to offer me $2000, don't even bother. If you come to look at it, I'll take you for a ride, you're not driving unless you have cash in hand (It's not because I think it's a Ferarri, it's just because I don't trust you.)
I will put more pictures up as soon as I can, you can PM me to get a hold of me. This car isn't perfect, but is a good base for a clean E30. I was planning to paint it but school, time and funds wouldn't permit that. I've been told it's one of the cleaner swaps, and I believe it after seeing some of the hack job 24v swaps.
PM me with any questions.
Sam
85 325 - Turbo M52B28.
Old 09-24-2010, 11:40 AM   #2
daveed
You should post a link to your build-thread in here.
daveed is offline   Reply With Quote
Old 09-24-2010, 05:22 PM   #3
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Originally Posted by SamE30e View Post
oh, and super dooper rare (I've heard and been told) OEM black headliner.
Sam
Up yours!!! Pull that thing out... we'll switch it for mine!!!
Oh, and if anyone wants the weaves, come to my place to get them... please!!!!!!! haha
Grow up and move on.
Old 09-24-2010, 05:50 PM   #4
SamE30e
SamE30e's Avatar
Oh shit, I forgot them!
Old 09-26-2010, 03:19 PM   #5
matty.dc
matty.dc's Avatar
Very well done swap! That price is a steal ! Good luck
2013 Ford Edge - Daily Driver
Old 09-26-2010, 11:15 PM   #6
E30M42cab
E30M42cab's Avatar
Just thinking... how much to leave them in my garage? Still have caps?
Old 09-27-2010, 08:36 AM   #7
SamE30e
SamE30e's Avatar
I do have the caps. They're in my trunk.
Just a note, I changed the plugs in the car, runs well now.
Old 09-27-2010, 12:42 PM   #8
E30M42cab
E30M42cab's Avatar
good. Now change the diff so I don't have to listen to you bitch about your milage!
Old 09-27-2010, 12:54 PM   #9
hockeyfan27
hockeyfan27's Avatar
...I'll take you for a ride, you're not driving unless you have cash in hand (It's not because I think it's a Ferarri, it's just because I don't trust you.)
funny...... and wise!
1998 328ic - Sold
Old 09-27-2010, 12:54 PM   #10
canuckder
canuckder's Avatar
How is the 4.10 ?
did you have a 3.73 before?
canuckder is offline   Reply With Quote
Old 09-27-2010, 02:06 PM   #11
SamE30e
SamE30e's Avatar
The 4.10 isn't bad. It's just like a stock 318is because it's essentially a 318is drivetrain. I wouldn't mind a 3.73 because I do a lot of highway driving and at 120km/h it does sit a bit high.
Old 10-02-2010, 01:42 PM   #12
richie_s999
This car is a perfect car to gut and cage, instant track rat, everything else is good to go!!
Old 10-06-2010, 11:20 AM   #13
SamE30e
SamE30e's Avatar
Bump, someone interested but nothing firm yet.
Old 10-11-2010, 12:55 PM   #14
SamE30e
SamE30e's Avatar
Sold!
Old 10-11-2010, 01:50 PM   #15
davericher20
black and blue
davericher20's Avatar
sorry to see it go.
But congrats on the sale
