Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Old 09-26-2010, 09:07 PM   #31
zerosignal
Got any change?
zerosignal's Avatar
ohhh man those are dope!!! i hope my city has a guy who can double that colour in powder coat for my style 66's!!!!
zerosignal is offline   Reply With Quote
Old 09-26-2010, 11:09 PM   #32
Back on topic..... The one thing that I forgot to mention was that while I was cranking at the bottom of the screen in tunerstudio it would say "not cranking" until I let go of the key, then I would see it change to red and say "cranking" for a split second then change back to "not cranking".
I'm not sure if that is typical, or if it's an indication of a problem?
I also just realized that I had forgotten to hook up the vacuum line to the MAP sensor in the ecu. I'm not sure if that would cause a starting problem in any way (i.e. the unit is looking for vacuum while cranking or something)?
Old 09-27-2010, 12:13 AM   #33
Yes, vacuum line would effect things, but not as much as cranking RPM. Whatever RPM you crank at (mines around 210rpm) you need to set Cranking RPM about 100 higher than what you see. If its set too low, then the vehicle doesn't see the engine as cranking and doesn't apply startup enrichment, etc.
What software are you using.. Tunerstudio I hope? I'd recommend buying the registered version and doing a crank position sensor log from the Diagnostics tab (composite log and tooth log). That will ensure you're seeing a stable and correct crank signal.
Then ensure you're seeing spark with the tried and true "pull the plug and look for spark" method.
Report back, good luck!!
Old 09-27-2010, 03:27 PM   #34
Yeah I'm using Tunersturdio. I don't think you need the registered version to use the composite log and tooth log. I have the free one and have access to the diagnostics tab. I even data logged a composite log while I was cranking and saved it to a file. I need to pull it off the laptop I was using though. Do I view it with megalogviewer?
Old 09-27-2010, 03:43 PM   #35
Oh, so you have a beta version. He's removed those tools in the newest ones I think.
Anyway, you view composite logs and tooth logs right in the diagnostics tab.
Old 09-27-2010, 04:11 PM   #36
I have version 0.999.7 and in the diagnostics tab there is only an ignition logger tab. I can't see any option to load logs either.
Old 09-27-2010, 04:13 PM   #37
Yeah, I think you need the regged version to do this. I have four types of logs, start / stop / time and an Open Log button.
Old 09-27-2010, 04:13 PM   #38
Honestly, supporting this software is worth it IMO. It is exceedingly good software.
Old 09-27-2010, 04:19 PM   #39
Yeah I'll be registering within the next few days.
How well does the VE analyze live work in terms of automatically tuning while you drive?
Old 09-27-2010, 05:35 PM   #40
It is quite good. I typically do a log, then have MLV (which I also bought, though its not as crippled) analyze it, new tune and repeat, but for cruise and light throttle stuff the VEAL can't be beat.
Old 09-27-2010, 09:38 PM   #41
I pulled those couple logs I made just to check them out. Apparently I'm not getting an rpm signal except for right when I let go of the key which is when I saw the "not cranking" box change to red and say "cranking". I also opened the tooth log and plotted it. I'm not sure how to interpret it though except that those 0 points are where the marks on the wheel are and the log software did pick up those positions because they were highlighted in the log.
Any ideas on the rpm signal?
File Type: jpeg 2010-09-26_12.26.18[trying to start car].jpeg (77.6 KB, 176 views)
File Type: zip 2010-09-26_12.26.18[trying to start car].zip (1.7 KB, 38 views)
Old 09-27-2010, 09:50 PM   #42
blk3
blk3's Avatar
off topic, you should relocate your coil to a less heat prown location. you would hate to have the coil fail on you because of too much heat soak.
blk3 is offline   Reply With Quote
Old 09-27-2010, 10:39 PM   #43
I was thinking of extending the wires from the harness so I could mount it further forward. but for now it should be ok.
Old 09-28-2010, 02:03 PM   #44
e30_kid89
The Afro-stig
e30_kid89's Avatar
change your "Ignition input capture" Under tach input/ignition options
Old 09-28-2010, 02:28 PM   #45
And enable noise filter.. those two odd spikes are noise which can be filtered easily. I have a thread on e30tech about it.
What settings are you running under tach input / ignition now?
