Old 08-10-2010, 09:22 AM   #16
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Jesus this could be a valve or a valve seal. 200 - 300 for the headgasket, related gaskets and valve seals. Tensioner belt and water pump as well. Could be carbon buildup on the exhaust valve seat. Get the head cleaned and checked.
Could be the rings, probably just the compression ring, sometimes the little spring gets all gummed up. Rings will cost you more but could be done for $500 I'd get new connecting rod bearings at the same time.
Did you do the test 2 times?
You can perhaps try an additive that may help free a ring that is sticking. Can anyone comment on a sea foam?
Old 08-10-2010, 12:38 PM   #17
new2bmw
testing
i am in the process of hooking everything back up right now so i can start it up and retest. i totally agree with doing it again. i want to make sure something is wrong before i give up. I tried to start it, could hear starter selenoid clicking but that was it. i am going to remove starter and get it tested. After that i will test it again. If it turns out to be good i will put it in, i have my fingers crossed . Ya new2bmw does seem outdated now lol
new2bmw is offline   Reply With Quote
Old 08-10-2010, 01:20 PM   #18
Boxer2
The OPP loves my M5
Boxer2's Avatar
Got a 5 spd swap available for your 318i, cheap. send me a pm for more details if you are interested.
My Garage:
1986 328is (M20 Stroker)
1986 535i (5sp all original)
1990 325iX (Mint 5sp all original)
1989 325iX (Winter auto X car)
1991 M5 x2
1988 M6
2001 740i (Supercharged)
1999 528iT (summer DD)
2004 X5 3.0i (winter DD)
Boxer2 is offline   Reply With Quote
