07-01-2010, 01:04 AM
Car: 328is
Lower strut bolt (E36) sheared off - what to do?
I was removing the suspension off my E36 and managed to get everything out, except the 2 lower bolts on the front struts. After much ado, I was able to get them off, but not before shearing the head off one of them. Now, half of the bolt is stuck inside my spindle / kingpin.
I tried taking the spindle out so I could take it to a shop to hopefully get the bolt remains out, but the 2 bolts holding the caliper on are too tight and it's hard to get any leverage on them (I end up just rotating the steering tie rod and control arm ball joint)
What should I do??
07-01-2010, 01:37 AM
Car: M5 Touring, 335i E92
Used spindles are pretty cheap! Let me know if you need one, got several of them
07-01-2010, 10:06 AM
Car: 328is
A used spindle would still require me to remove the calipers, which I've been unable to do...
07-01-2010, 10:57 AM
Car: 91 318is,93 325is...
if your taking the spindle off undo the brake line and sensor wires. This will allow you to remove the caliber with the spindle and you can vise it and get more room on the bolts to brake them loose
07-01-2010, 12:54 PM
Car: Gettin One Soon
Undoing the bake line with out breaking it would probably be harder then getting the caliper off.
1995 E36 318is
Engine Mods: 94 M50 motor, Lightweight Flywheel, SACH clutch, UUC shifter, Electric Fan, Header and Full Exhaust, Magnaflow muffler, CAI, Racing Dynamics Chip
Exterior Mods: M3 spoiler ( Not installed yet), Projector Headlights, M3 mirrors.
Suspension Mods: Front Strut bar, Eibach spings, Billstein Struts.
Interior Mods: M3 buckets, Reverse Glow gauges, Momo steering wheel, M3 Shift Knob, M3 Headliner
07-01-2010, 05:04 PM
If he can't get enough leverage to break the caliper bolts off it's alot easier to undo the line where it bolts to the caliper. It's a rubber line and has flex it shouldn't break.
07-01-2010, 07:15 PM
Singhy
Car: '98 323is
spray-on penetrating fluid should help. I recently did the same job and pre-soaked all of the bolts the night before. The other option you have is to use a torch to heat them up, however I leave that as a last resort and avoid if at all possible.
07-01-2010, 11:11 PM
Car: 90 325is DD
DO NOT apply heat to any of your brake lines/components. Brake fluid has an incredible amount of energy in it, and will explode if heated too much. Just make liberal use of penetrating spray, and use the best tools you can find as to not destroy the brake line fittings.
328is is no more  new project!
07-02-2010, 02:23 AM
Then you should put that as the "main" problem! Even if there was a magic fix for the broken bolts, wont do you any good at this point!
"I tried taking the spindle out so I could take it to a shop to hopefully get the bolt remains out, but the 2 bolts holding the caliper on are too tight and it's hard to get any leverage on them (I end up just rotating the steering tie rod and control arm ball joint)"
At this point you use the steering lock! Wont move on you. Turn it full opposit of the side you are working on, and use an extention (like a pipe etc) to get more force to it. (99.9% chances are it will come off!) or the caliper slider will brake (never seen it happen on a BMW before tho!).
07-02-2010, 01:34 PM
#10
Not saying that its not possible, but i had to remove TONS of break line fittings in the trade, and torch is #1 tool to get them off, first time i hear about not heating them. Just gota use some common sense when heating it.
1995 E36 318is
07-02-2010, 07:50 PM
#11
Car: 90 325is DD
this is a case of "do as i say not as i do" lol. I've had to heat brake line fittings before (like you, I'm in the trade), but there is a very fine line between enough heat, and too much. I learned that lesson the hard way.
If the OP doesn't know what hes doing (no offense to OP, I don't know you or what you do for a living), the best advice one can give is to use less extreme methods.
As for the caliper/carrier bolts, the biggest bar you can find will be your best friend, as was already mentioned.
07-05-2010, 10:04 AM
#12
Car: 2007 328XiT
A good impact gun will work ... almost every time.
08-01-2010, 08:20 PM
#13
Car: 328is
Finally had some time to tackle this. Tried my share of drilling / extractor sets to no avail. I will have to remove and probably replace the spindle. All the nuts and sensors are disconnected, the only things holding the kingpin assembly to the car are:
-brake line: should I disconnect at the caliper or at the hard lines? I don't have a flare wrench.
-tie rod ball joint and control arm ball joint: the spindle is stuck on the studs tight and I can't get them to budge, despite both being very new (spindle is old though). Any suggestions on how to remove these, what to jack, what to support, where to apply force, etc.?
08-01-2010, 11:35 PM
#14
Car: 2007 328XiT
Just unbolt the caliper from the spindle and leave with the car.
For the tie rod and control arms, put the nuts back on about half way through the nut but so stud does not proturde. This way you can whack it with a BFH and not damage the stud, only the nut will be damaged (and you replace those anyway).
Next, hit the side of the balljoint with a hammer ... this helps loosen the bind. Finally, apply some heat to the spindle around the stub. be carful not to melt the ball joint boot!
Good luck! Getting those off is a bitch withouth the proper tool. A generic ball joint spereader might work as well ... princess auto has them, but I think they are too thick, but you might be able to modify it.
