06-19-2010, 01:43 AM
SweetXi
Car: 2004 330Xi
Any Electronics designers want to assist in a VERY cool mod?
Some of you may have seen my previous posts in regards to retro fitting a DCT shifter from a 2010 650i to my Steptonic e46. With my black interior, and black CF trim, should look sweet! Not my car; someone that tried and almost got it there......
BMW's current lighting system on the e46 uses a common power, switched ground design. PRND LEDs are lit when the selector switch closes the circuit to ground.....
See schematic below.
The challenge is that the DCT shifter uses a common ground, switched power design to illiuminate PRND LEDs. I've traced and determined the pin connections for the DCT shifter and got ambient lighting on the shifter to operate through car dash lights. Got green LEDs to illuminate by applying Dimmer power directly to applicable pin and varying intensity (best appearnce @ around 6vdc; don't know spec of LED installed).
Where everybody previously had failed is getting it to operate in the car.
The circuit I have in mind would use the switched ground connections of the current design to trigger a micro relay or opto coupler which in turn would provide approx 6vdc to the LEDs (drop voltage across resistor). Replicate circuit 5 times PRND and M/S. Simple design and I am an electrical engineer by trade, but been out of industry for close to 20yrs and sorta behind on mre technology available to me. Spent evening browsing Electrosonic catalogue and think I've got the relay identified....
Just need some assistance in fine tuning and double checking to ensure the components selected are appropriate for application.
Just a little of your time to help make this work........ Any takers?
My Ride:
2004 330Xi
DCT Electronic Shifter
Bilstein and H&R sports suspension, Rogue Enginerring Race Brace
AA Stage2 tuning
Conforti CF Cold Air Intake
Hamann Front Spoiler and Side Skirts
BMW OEM rear wing spoiler.
M3 SMG Paddle Steering Wheel and M3 Seats
18" M6 custom painted wheels
Custom red kevlar interior
Magnaflow Exhaust
VIS CF Hood
06-19-2010, 10:14 AM
Car: 74 tii, 93 M5x2, e90
LED's work on a constant current and most will work well with 20 to 30 mA flowing through them. Use a milliamp meter to measure the current as you vary the voltage, and you will see that it will look pretty good when once you have 20mA flowing through it.
06-19-2010, 10:26 AM
SweetXi
Car: 2004 330Xi
Thanks MarkD. My biggest concern is overall current usage when car is off and loading on the battery. I will use the mA meter to measure real voltages and currents to make sure I don't exceed the rated specs of the individual components. If I use micro relays, my concern is the coil must be energized to light the "P" LED. Not sure what would be considered high draw when car is off. Also going to integrate built in electronic shift lock (lose mechanical lock with new shifter). Going to pass the Electronic Shift lock through "P" switch on shifter so you have to have both the brake pedal depressed and "P" button pressed in order to shift gears. Safety concerns addressed.
My Ride:
2004 330Xi
AA Stage2 tuning
Magnaflow Exhaust
VIS CF Hood
06-19-2010, 12:39 PM
You can control the LED's with a small micro controller and have all the LED's plus the micro go to sleep 5 minutes after the car is parked, to save power.
Generally, it's best if you can keep current draw of any device you add to 10 mA or less. (when engine off and car is parked)
I can't even see where the LED's are in the schematic you posted.
You can buy a small evaluation kit for various micros and develop the project on that. (under $100) You would have to write the code in C, but you would probably have some fun doing it if you are rusty at it now.
This demo board will probably be exactly what you need if you have around 5 LED's to control:
http://www.silabs.com/products/mcu/p...rontpanel.aspx
If you are wondering how that board will help you, what I suggest you do with it is use the touch sensor inputs and the IR inputs as inputs from the shifter, and use the LED outputs to control your LEDs. You have to re-write the supplied code to not work as touch inputs, but regular inputs. It would be very easy with that demo board.
06-19-2010, 11:41 PM
SweetXi
Car: 2004 330Xi
Interestingly enough, BMW does not show the actual LEDs on ANY schematic I can find. I suspect they are triggered by the line shown immendiately above the transistors. Transistor is forward biased, pulls the signal line above it to ground engergizing the LEDs.
Checked the above link.... VERY cool. Will be doing some reading tonight!! LOL.. A simple PLC (effectively what they have here) would do the trick, but I no longer have the compilers; nor am I current on the PLCs available today. This looks like an excellent solution. Even the best micro relays seem to be comsuming 180 - 200mW.
THANKS!
My Ride:
2004 330Xi
AA Stage2 tuning
Magnaflow Exhaust
VIS CF Hood
06-20-2010, 12:15 AM
Your welcome. The complete IDE (integrated development environment) and compiler that will compile and link small projects is usually free and I am sure you get all that included in this kit, which cost around $40.
06-22-2010, 08:53 AM
SweetXi
Car: 2004 330Xi
I posted a similar thread on e46Fanatics site and a member from the UK came up with this design; simple PNP transistor is drive the LEDs. Think this might be the answer. Should be able to source 20-30mA current through the transistor. Although he connected to wrong pins (didn't realize I was retro fitting to e46), the circuit should work prefectly!! Going to test bed it over next couple of days and see how she works.
My Ride:
2004 330Xi
AA Stage2 tuning
Magnaflow Exhaust
VIS CF Hood
07-02-2010, 12:50 AM
SweetXi
Car: 2004 330Xi
It's WORKING AND INSTALLED!!! :woot:
Quick cell pics for now, but it's installed and operational.....
Have to find someone to sew the leather and make it look factory......but it runnning....
required isolating selector switch and using relay on M/S signal...... pulled pieces from original board (extra I bought for this purpose)..... but other than finishing (enabling P shiftlock, covering old PRND indicators and leather)..... it's DONE
DIY to follow....
My Ride:
2004 330Xi
AA Stage2 tuning
Magnaflow Exhaust
VIS CF Hood
07-02-2010, 08:22 AM
SweetXi
Car: 2004 330Xi
bump
My Ride:
2004 330Xi
AA Stage2 tuning
Magnaflow Exhaust
VIS CF Hood
