Old 06-17-2010, 10:19 PM   #1
agentM
Detailer, tint, Chipguard
agentM's Avatar
smoke test
Anybody know where I can get a smoke test in T.O. Thanks
Old 06-17-2010, 10:47 PM   #2
You're talking about a way to find leaks? I prefer a quiet area with 15psi of air pressure instead. The smoke test may not reveal areas that leak only under boost.
Go to princess auto and find the parts to make a cap of your intake pipe and drill and tap a port for an air inlet. Then get a compressor and push air into the intake pipe, and listen for leaks.
Old 06-17-2010, 11:04 PM   #3
agentM
agentM's Avatar
When you say make a cap for the intake pipe, do you mean take all six pipe off and cover it with a cap? When its under pressure wouldn't the air come out of the BOV? Still not sure. thanks for the help.
Old 06-18-2010, 12:49 AM   #4
Six pipe? What do you mean?
I meant take off your air filter, and make a cap that will cap the intake pipe where the air filter bolted on, if possible. I'd have to know the layout of your intake piping, I guess. More details?
The BOV should be shut with no vacuum to pull it open, if its open at 100kpa (0 psi of boost) then you're venting boost, ie, boost leak. You'd need to adjust the BOV to be closed at 0 PSI.
Old 06-18-2010, 07:01 AM   #5
agentM
agentM's Avatar
IC, thanks, I'll try it in the weekend. That's a big cap I have to buy since the air filter is about 5" wide.
Old 06-18-2010, 11:23 AM   #6
is it round or square? if its round, the filter might be 5" but the pipe will not be that big.
Old 06-18-2010, 12:02 PM   #7
bmwconnect
BMW Tuner
bmwconnect's Avatar
something like this works just great.
bmwconnect is online now   Reply With Quote
Old 06-18-2010, 02:50 PM   #8
Yeah, that's what I was trying to describe!
Old 06-18-2010, 08:33 PM   #9
agentM
agentM's Avatar
It's round. Is that where you got from Princess Auto?
Old 06-19-2010, 12:43 PM   #10
You can get the stuff needed to make the adapter in the pic at Canadian Tire, Princess Auto, etc.
Old 06-19-2010, 06:18 PM   #11
agentM
agentM's Avatar
If I do this myself I will have to take a view things apart. I have to take my fan, then the blower. Then the hose to the intake manifold. Take the under cover , jack up the car, dam, I might want to give it to the shop to test it for 1 hr service. The have the smoke to test and it will be easier for them. Thanks for the info, I have to see if I have time for this. It took me 18 hrs to put this S/c in.
What is that cover made of in that picture? What section in Canadian tire can I find that rubber cover?
Old 06-22-2010, 12:27 PM   #12
uzi577
RUNING BOOST
uzi577's Avatar
Post
hi agentM
I too suffer form chronic vacuum leaks.I am wondering if you made any head way with this contraption.
uzi577 is offline   Reply With Quote
Old 06-22-2010, 05:15 PM   #13
agentM
agentM's Avatar
Originally Posted by uzi577 View Post
hi agentM
I'm so busy at work I didn't get a chance yet. I probably do it if I had time. I might just go to a shop and get a smoke test. I think it's pretty easy to find out my leak but I have to find time. I'm only loosing 1 psi so I'm not leaking that bad. I think.
Old 06-22-2010, 05:25 PM   #14
boost leaks are not as bad on a supercharger setup. a turbo boost leak can mean the end of the turbo due to overspeed.
Old 09-02-2010, 02:58 PM   #15
uzi577
RUNING BOOST
uzi577's Avatar
HI Agent
Any updates, Did you get around to it?
