Go Back   maXbimmer Forums > Platinum maXbimmer Sponsors > Bimmersport Automotive
Old 06-08-2010, 10:01 AM   #1
BMW_7
Econobimmer Racing
BMW_7's Avatar
rear shock tower completely torn off from body: safe?
as the title says... how dangerous is that... and have you ever seen this on a e36 before and fixed it successfully? (its only on one side, shock mounts are fine)
The mechanic Im with looks like he is doing a good job, spot welding all around it and then he says he will weld pieces of metal if needed.
im also looking into a rear strut bar to help keep the shock tower stable
anything else Im missing?
Vitaliy
Helprace, a helpdesk & community platform
Old 06-08-2010, 10:22 AM   #2
Jon@Bimmersport
Jon@Bimmersport's Avatar
We have seen this before....as long as you are confident in your mechanics ability to weld and seal properly. Your option to go with a strut bar or re-inforcement plates is my recommendation as well, preferably the strut bar. Inspect the other side while your at it.
Old 06-08-2010, 10:32 AM   #3
328IScreamer
328IScreamer's Avatar
reinforcement plates are a good idea
I have seen this a few times and the plates are definitly a requirment. make sure to undergaurd the plates so they don't rust, also be sure to use a pretty good sized gauge of steel so it's nice and solid.
Once welded in this should fix the issue for life.......oh and usually if one side goes your other side isn't too far behind. Insoect for cracks and if there is even a hairline I would replace both sides. It actually would be a good idea to do both sides anyway but I know it can be costly.
Old 06-08-2010, 12:34 PM   #4
BMW_7
Econobimmer Racing
BMW_7's Avatar
Thanks a lot Jon and Screamer
Well reinforcement plates go on the top of the shock tower correct? that area is fine, the problem is around the actual tower
im guessing a rear strut bar is all i need then...
Vitaliy
Old 06-10-2010, 08:34 PM   #5
propr'one's Avatar
put z3 re-enforcement plates or e46 m3 rsm's while you're in there.
Hot: 2001 Estoril M RoadsterZCP 19's michelin PSS, ZHP knob, JL 8W3
Cold: 2002 TiAg M3 6mt deoranged, dechromed, led tails, ZHP knob, UUC SS v3, GROM, OEM 18's w310's,
Fun: 2006 YZF-R6, black, ohlins, pazzo, BMC, cat delete, vance hines csone, YEC racing tune,-1 +2
Old 06-10-2010, 09:26 PM   #6
Check the link on bf.c there was a nice how to on there, usually they replace the whole tower with a new pre-made piece of steel.
Old 06-11-2010, 05:30 AM   #7
MarkD
MarkD's Avatar
Or cut the tower out of a scrapped car. It's better than having someone patch in bits of metal, you need rigidity in the towers.
Old 06-11-2010, 08:23 AM   #8
E30 Girl
E30 Girl's Avatar
Send a message via MSN to E30 Girl
When I did this to my car I bought my reinforcement plates from Turner Motorsports they come anodized and then we just hand sanded the sides to weld and the rest was still covered so it wont rust. Then I cut away the rust on the tower and welded the plates in, this was three years ago with lots of track time and have no rust or problems.
E30 Girl is offline   Reply With Quote
Old 06-11-2010, 08:33 AM   #9
Now that i am on a computer, i found the DIY i was referring to.
http://forums.bimmerforums.com/forum....php?t=1429052
Is this what yours looked like?
The new Piece.
The fix
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
