Old 04-09-2010, 05:43 PM   #1
Dammerung
Dammerung's Avatar
E38 740 brakes upgrade
I believe the 750 has the two piston calipers and bigger rotors in the front. From what i kno the brake lines are the same. So doing a swap shud be easy. Wonder if its possible to get a hold of the front 750 calipers in good condition. Better brakes never hurts
The rear is the same in both cars im quite sure. Any insights?
has neone tried this? Or have a better brake mod?
Note: Image of black E38 is of a 750 with newly installed brakes.
Die Dämmerung..............when dusk began to fall, when dawn begins to break
Dammerung is offline   Reply With Quote
Old 04-11-2010, 10:22 AM   #2
First off, for the 750 brakes, you will need the rotors, calipers and the carriers from a 750. Best bet is to find a junker that has a 750 to take parts from, but that is rare.
Yes the rear brakes are the same.
IMO, the additional stopping power vs. the $ for this upgrade is not worth it, unless you are putting down some serious power, moreso than a 750.
I just purchased Brembo rotors (blanks), Akebono Ceramic pads and SS Braided lines that should be going in sometime soon.
Follow me on Instagram @SEVEN40iL and Twitter @SEVEN40iL
Old 04-11-2010, 04:44 PM   #3
Dammerung
Dammerung's Avatar
Ahh forgot about the carriers...that is very important. Cost wise its not that much actually. Just front rotors and pads I can get at a moderate price. The problem is finding the calipers. I have found used ones from Bavauto for 75 bucks a piece. Ill do the job myself so tht will save me some money as well.
I currently have brembos drilled and the ceramic pads.
Old 04-12-2010, 09:37 PM   #4
V12
Actually the 750 rear rotors are different too - bigger and ventilated.
Doing it yourself makes sense, as it is only a few bolts.
E38 5.4L V12
V12 is offline   Reply With Quote
Old 04-13-2010, 06:09 PM   #5
Hey bud, haven't seen you for a while! Hope all is well and you are ready for some meets this summer
Old 04-14-2010, 12:50 AM   #6
Dammerung
Dammerung's Avatar
Hi V12,
Do you know if the brake booster is different as well. Im thinking if the 750 has bigger brakes altogether it will probably have a stronger brake fluid pressure. The rear therefore have different calipers aswell?
Old 04-14-2010, 02:22 PM   #7
V12
Always From the looks of it you have your car all prep for summer. I am shedding my snows and putting on my style 95 today, wax and shine and hope to change all 12 plugs today too.
Originally Posted by Dammerung View Post
Hi V12,
What is diff: Caliper, carrier, and disc.
I checked the part numbers and the brake booster are the same. Usually there should be a proportioning valve to balance front and rear and the progressiveness of the brakes but I am not sure where this is on th eE38.
E38 5.4L V12
Old 04-14-2010, 08:38 PM   #8
Nice! Give me a ring when you want to cruise!
Old 04-14-2010, 09:40 PM   #9
Dammerung
Dammerung's Avatar
Thanks man tht helps. If the booster is the same then the propoertioning valve should be the same as well. Im quite happy with the brakes actually just thought if its an ez job why not have stronger brakes. couldnt hurt now could it
Old 04-27-2010, 01:46 PM   #10
So did you do the upgrade?
Old 04-27-2010, 09:50 PM   #11
Dammerung
Dammerung's Avatar
no harder than i thought to find decent calipers from the 750 and forget about the carriers.
by the way we apparantly have a common friend. He told me about your front number plate situation. I have a good solution to that. We should meet up. howz tommorrow? I live downtown. Let me know where you would like to meet up. Ill txt u or smthn
