04-02-2010, 11:15 PM
#1
Car: '97 M3
So I have 235/40 R18's on my BBS CH rims
Offset is ET35 and it appears that the tires just fit snugly. Who knew what 0.2 radius difference could make a difference.
Is there any reason to be concerned as on one side of my car, I can run my finger between the fender and the tire, but the other side is a tight fit, really tight fit....
When pressing down on the suspension, I don't seem to notice tires hitting any fenders, or the light, but am curious to find out if I should get it checked out. I have to get an post-winter oil change and for some reason the check engine is asking me to check the "coolant" level.....so, it would be coming in soon.
Thoughts.
Paul
04-03-2010, 12:16 AM
#2
Car: '00 540i
They say BMW's have one side higher than the other due to driver weight compensation. I know both my E36 and E39 are/were that way.
If you have any rubbing, you could always get your fenders rolled...
93 325is - sold!
2000 540ia- sold!
04-03-2010, 12:48 AM
#3
Car: '97 M3
This would make sense.... ;-)
I will look at it tomorrow with a sound mind....was a little flustered today with the A/C not workin on my e90....and my gf complaining about it a little thinking stuff like this should not happen....which I agree.....
Paul
04-03-2010, 10:49 AM
#4
Car: e30 with e91 beater
A/C failure on the E90? Ouch. Are you talking about the front or rear fenders? It could be a bent control arm on the front (if the wheel is forward or rearward) or a broken spring, crushed spring pad, failed strut bearing, etc, if the car is lower (so the wheel is tighter to the fender all the way 'round).
BTW, Princess Auto now sell the Eastwood fender roller. I'm waiting for it to go on sale and I'll be making a post about a purchase where we all go in. I'll like to have another go at my rears.
04-03-2010, 04:16 PM
#5
Car: '97 M3
yes.....e90.....go figure, it blows cold'ish air.....but it is not that cold. and definitely doesn't blow 16 degree's on max A/C.
Back to e36.....drove it around.....and I think it is fine....but I went in to a parking lot and when the wheels are fully turned, I do see the rear of the tire hitting the inner wall....on the rear.....
And I do think I am cutting it close...but not sure.....
Sheesh....
Paul
04-06-2010, 03:50 PM
#6
99 ///M3
Car: E36 M3
You want to see close, look at mine next time you are here.
Sheesh....
Paul
04-06-2010, 03:53 PM
#7
Car: '97 M3
I put the 17"s back on because I need the rear fenders rolled up and some minor plastic fender liner adjustments in the front wheel well. I am surprised that the wheel well liner covers so much space.
Paul
04-06-2010, 08:27 PM
#8
I did a quick check on 1010tires.com.. 225/40R18 are already bigger than the oem size, so 235/40R18 are quite large, about 18.3MM larger than OEM size, plus they're a lot wider. Tire selection is limited, but a 245/35R18 might have been a better choice.
Anyway, you might be able to mold the inner fender with a heat gun. There are a few fender rollers around the city but most people are reluctant to lend it out. I guess Princess didn't renew their order for them; too low of sales.
04-06-2010, 09:37 PM
#9
Car: '97 M3
yeah...I realized that after the fact and I based it on someone else running 235/40 R18's but I think he was using a slightly different offset and he didn't tell me he was rubbing as well. I would not have gone that route.
Right now, as the BBS rims are refinished and painted, I may consider selling the 18's with the wheels (or not) and for a good buck too and get LTW's in 17" or a proper offset 18" rim set to make sure the 18" tires fit. However, the 17's look large enough with this chassis anyways.....
I am sure I will find a buyer for the 18" BBS rims....
Paul
