Old 03-16-2010, 08:57 AM   #1
Nguyen_E30
0011 0001 1000
Need Help!!!
So my car has been on my driveway since like December? Car was kept in gear. Brakes seem really rusted. Tried moving the car today but it wont budge. Got a friend to tow it with his bimmer but no budge!!!
What should i do? I have replacement discs/pads which I plan to put on. Should I just jack it up on my driveway and replace them like that?
HELPPP
Nguyen_E30 is offline   Reply With Quote
Old 03-16-2010, 09:11 AM   #2
hockeyfan27
hockeyfan27's Avatar
Did you leave the E-brake on? Does it feel like it releases? On another car, I had one of my e-brake cables rust and it wouldn't release.
1998 328ic - Sold
Old 03-16-2010, 10:29 AM   #3
nachos23
SweetXi
nachos23's Avatar
See if you can release the calipers in the same way you would do so when doing a brake job. Wedge a long screwdriver into the opening in the caliper so it lodges in the vents in the rotor. Dont press against either outside surface of the rotor (will damage surface). Then pull towards you to force piston back in and hopefully free up calipers..... however, you don't specify man/auto. If its a manual and you've had your e-brake on the whole time, I would agree with hockeyfan27 a good place to start would be the e-brake.
My Rides:
2009 335Xi
520HP
H&R coilovers
BBS LM wheels
//M sport package
BMW Personal Audio System
2000 Z3M
Conforti tuned
AFE CAI
++More to come this winter
Old 03-16-2010, 12:14 PM   #4
pawcio
pawcio's Avatar
based on my previous experience, if it is your e-brake cable that completely rusted and seized, then you won't be able to move the handle.
__
pawcio is offline   Reply With Quote
Old 03-16-2010, 12:39 PM   #5
hockeyfan27
^^ I've had that happen and I've also had the e-brake portion of the caliper seize so the handle moves freely but does nothing.
1998 328ic - Sold
Old 03-16-2010, 05:38 PM   #6
pawcio
pawcio's Avatar
^ your cable must have snapped in the handle moved freely, no? because mine was stuck solid.
__
Old 03-16-2010, 06:24 PM   #7
parm
Scarboro Mazda S&L
parm's Avatar
If the E-brake is stuck, Get a hammer and start banging around the rotors hopefully it can release and you can move the car.
Old 03-16-2010, 06:52 PM   #8
Nguyen_E30
0011 0001 1000
No my ebrake wasnt engaged. I knew not to leave it on during the winter. I'm gonna do the brake job as I have recently purchased rotors/pads. I was planning to drive it into the garage to do it but its stuck outside!
Edit: Its a 5 speed!!
