Old 03-13-2010, 01:07 PM   #16
ScotcH
Yes, I think it's a diff between sedan/coupe. Our seat mounts from e36 coupe would NOT fit into e46 sedan. Close, but off by about 1/2". This leads me to believe that the sedan seat mount a bit differently from e36 and e46 couppe.
Old 03-15-2010, 11:35 AM   #17
INFAMOU$
Automotive Puppeteer
INFAMOU$'s Avatar
Send a message via MSN to INFAMOU$
Well I will finish this thread by confirming the following.
Coupe seats from the 330 directly bolted into my 325IS. The rear bolts were a little tricky to get in but a pry bar fixed that.
Spade connectors (female) work perfectly as ground and power adapters for the power of the seats. I did run a 10awg wire down from the fuse box for the extra draw in power.
INFAMOU$ is offline   Reply With Quote
Old 03-15-2010, 01:30 PM   #18
5style
Hatters gon Hatt
5style's Avatar
Not true, I put in Ti m tech seats into my coupe ( Ti has the sedan floorplate) and they fit fine.
Bmw_7 put in coupe seats into his sedan, again no issues.
Old 03-15-2010, 04:35 PM   #19
theblue
old school US member.
theblue's Avatar
cool! how much of a pry are we talking about... with mine you couldn't see the bolt hole until you started to file.
02 BMW X5 // 97 BMW 328iC // 89 325is w/ M50 swap // 06 Audi A3 w/ APR stage II
Old 03-15-2010, 05:04 PM   #20
ScotcH
e46 SEDAN not e36 sedan (which is the same as an e36 coupe, and e46 coupe). What can I say ... our e46 SEDAN has different bolt pattern than the e36 coupe. Maybe they changed mid model or something, but the 1999 e46 SEDAN seems to be different.
Old 03-15-2010, 09:09 PM   #21
INFAMOU$
INFAMOU$'s Avatar
You could see the hole.. the bolt would just not start unless you wanted to cross thread them! It was the hole closest to the transmission tunnel in the rear that was the problem on both seats..
