02-25-2010, 10:05 PM
Car: '89 325is
Tie Rod Replacement
Hi Everyone,
Just finishing off my steering work and replacing the outer tie rods.
One of them screwed onto the steering knuckle tight, but for some reason I can't tighten the other one. It just seems to rotate the entire ball joint.
Does this mean that the rod is broken? Why did one tighten right up, and the other will not tighten up much past hand tightening?
Any help is appreciated (I bought pretty good quality, life time warranty, so it's not because of the equipment)...
02-25-2010, 10:10 PM
The Afro-stig
Car: Is Fast. ;)
Put a jack under the ball joint, keep lifting till you just start to lift the entire car. (hear creaking noises)
You will be able to tighten the ball joint then.
Goodluck!
02-25-2010, 10:19 PM
Car: 01 320i mpackage
or use a channel locking plier and squeeze the joint while tightening.
02-25-2010, 11:00 PM
Car: God's Chariot
Use the jack method. Much less chance of damaging something than with that plier solution.
02-26-2010, 08:09 AM
Car: '89 325is
Thanks guys, I will try that tonight, hopefully I can get it done before 9:30 lol
02-26-2010, 10:48 AM
Car: 325ix,325ix,325ixt
are you talking about the tie rod end threading onto the inner part? or the balljoint into the strut? If you're talking about the end(#8 below) onto the inner(to make a #4), you will not use a jack, but use visegrips or a pipewrench to hold the inner while you thread the end on far enough that you can drive to get an alignment. If you can't tighten the nut on the balljoint(#9), use a jack as described above.
02-26-2010, 04:34 PM
Car: '89 325is
Cool diagram, thanks. Yes, it is #9 that is causing the issue. I will try the jack method and post tonight.
02-26-2010, 08:09 PM
Last of the Late-Brakers
Car: 1992 M5
The diagram is from http://www.realoem.com
If you're working on a BMW you should really get familiar with that site, it's like the bible but without all the lies
02-26-2010, 10:46 PM
black and blue
Car: ix touring
 1989 325 IX Touring
02-27-2010, 11:14 PM
#10
Car: '89 325is
Goodluck!
Great advice, it went on perfectly when I did this. Thanks!
02-28-2010, 12:27 PM
#11
The Afro-stig
Car: Is Fast. ;)
03-01-2010, 12:39 AM
#12
Parts Hoarding Specialist
Car: '91 318i, '91 318is
Brent, it's funny how you got the damn things off without using the jack... usually the nut spins the ball joint when you try to undo that same nut.
1986 E30 325e (killed)
1986 E30 325es (died)
1988 E30 325i (rotted)
1992 E34 525i (sold)
1992 E30 318i (cabrio, Dad's)
1989 E30 325i (Mom's)
1991 E30 318is (Winter car)
03-06-2010, 05:54 PM
#13
Car: '89 325is
It's been a while since I took them off, but if I remember right I think I may have just cut them off with my trusty $10 rotary tool from Canadian Tire...lol
