Old 02-01-2010, 03:43 PM   #1
dil
dil's Avatar
NEED CYLINDER HEAD ASAP m52 2.8l
Anybody got or anybody know if u can fix cracked heads
dil is offline   Reply With Quote
Old 02-01-2010, 03:48 PM   #2
dil
dil's Avatar
need asap
Old 02-01-2010, 11:10 PM   #3
richie_s999
Cracks can be welded and then the area can be machined but it's usually better and cheaper to get a new one.
Old 02-01-2010, 11:24 PM   #4
If you would consider full engine, or if you are going to rebuild it (the head), let me know...i have both available.
Old 02-02-2010, 05:27 PM   #5
dil
dil's Avatar
the head is slilighty cracked in between valves any body got low mileage heads
Old 02-02-2010, 10:23 PM   #6
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
www.car-parts.com Should be useful.
ACS_DAN is offline   Reply With Quote
Old 02-03-2010, 01:06 AM   #7
PROJECT_E36
might be usefull info, m50,m52,s50,s52 are the exact same heads but with different cams. good luck with your search
PROJECT_E36 is offline   Reply With Quote
Old 02-03-2010, 01:22 AM   #8
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
That's not entirely true.
Old 02-03-2010, 01:23 AM   #9
PROJECT_E36
elaborate plz
Old 02-03-2010, 01:37 AM   #10
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
The difference is in the Valve train, Springs, retainers etc.
Regarding springs.
http://forums.bimmerforums.com/forum...ompare+springs
The non Vanos M50 also uses a slightly different valve than the rest.
Old 02-03-2010, 01:42 AM   #11
PROJECT_E36
yes you are right, but when i said head i meant bare head, scince he already has good, cams springs, lifters, trays and valves. Just to correct myself its m50tu, not m50.
Old 02-03-2010, 02:00 AM   #12
If you start swaping internals, might as well rebuild the head! He just wants a quick fix...
If it was my car, i would get a used head and have it rebuild by a good shop, after that you have an almost new engine!
Old 02-03-2010, 03:23 PM   #13
Darkness95m3
Darkness95m3's Avatar
New cylinder head will cost you $3000, that's just for a blank head.
Cracks can be welded and machined, however you are looking at $1,500+
Darkness95m3 is offline   Reply With Quote
Old 02-04-2010, 03:25 PM   #14
MANDD
Autobahn East
I should have a couple, get the casting number from the side of the head. and PM or call me.
905-686-2700
Mark.
