93 318is cranking but not starting
Drove home from work Boxing day morning. Had to drive through a huge puddle. Battery light came on, think car kind of slowed, then all was good. Can't remember if I drove the next day or not, but then when I went to start it, would crank but no start.
Main relay - voltage at terminal 30 and 86
Fuel pump relay - voltage at terminl 30, voltage at 86 when key on
still have to check fuel pump
crankshaft position sensor reads 580 ohms between pins 1 and 2; Bentley manual says 1280 +/- 10 but internet says Bentley may be wrong.
What do you think ? ECU cooked ? Any advice ?
