Old 12-08-2009, 06:42 PM   #1
jarr3d
Black 2003 BMW 540i M-sport Headlights
Hello, i currently have the stock halo xenon's, and they are a little fogged up and dirty. I decided i would just change them all together, rather than taking another approach.
Would anyone be able to suggest a new set of headlights that are quality, and look nice? i would prefer them to still have the halo look to them.
jarr3d is offline   Reply With Quote
Old 12-09-2009, 04:01 PM   #2
Qube
Quality eh? Euro Hellas. Expect $1600 or so shipped.
Going cheap? Grab DJ Auto's. Just expect to replace them every 8 months or so from pitting, fogging, or other wonderful things.
Qube is offline   Reply With Quote
Old 12-09-2009, 11:57 PM   #3
jarr3d
thank you
Old 12-10-2009, 12:32 AM   #4
Gamite
Gamite's Avatar
Picked up my euro hella's from umnitza for around 900
www.gamite.net
Old 12-10-2009, 12:34 AM   #5
jarr3d
Are the euro hellas a lot nicer than stock?
Old 12-10-2009, 01:39 PM   #6
Max_VQ
Max_VQ's Avatar
Polish them!!! They will look like new when done. It takes about 30 minutes each and supplies should cost less than $15 total.
Old 12-10-2009, 04:09 PM   #7
jarr3d
Sounds like its worth trying, do i polish the outside? or is there anyway to get inside?
Old 12-10-2009, 09:10 PM   #8
Max_VQ
Max_VQ's Avatar
Usually the plastic on the outside is beat up and dull and that is what you polish.
You can get to the inside by heating up the adhesive and carefully pry the headlight cover off. I did this when I changed my headlight adjusters. Why do you want to get inside the headlight?
I have read the BMW changed the adhesive in 03, and they can not be removed by heating and prying.
I wet sanded starting with 800, 1000, 1500, 2000 grit paper. Then I used the drill and cotton wheel with aluminum polish. (Yes, it works great!)
BTW, you don't have to remove the headlights to polish them. I was changing my aux fan, and they needed to come off.
Here are my results:
Old 12-10-2009, 11:26 PM   #9
jarr3d
looks good. I guess it would be best to remove the headlights?
Old 12-10-2009, 11:29 PM   #10
Gamite
Gamite's Avatar
totally forgot about the polishing option. Yes best to take the lights off first, makes the process a lot easier. Also it pretty easy to get the lights off.
www.gamite.net
Old 12-10-2009, 11:32 PM   #11
jarr3d
i'm going to give that a try i think.
One more quick question...
am i able to change the color of the yellow rings of light?
Old 12-10-2009, 11:55 PM   #12
myndgone
..... kLaSSe~1 .....
myndgone's Avatar
Send a message via MSN to myndgone
wow, that actually looks pretty good....good job man!!
myndgone is offline   Reply With Quote
Old 12-11-2009, 09:27 AM   #13
Max_VQ
Max_VQ's Avatar
Sure can, you just need to buy a different bulb for the "angel eyes"
google "e39 angel eye bulb" for more info...
Old 12-11-2009, 09:29 AM   #14
Max_VQ
Max_VQ's Avatar
I think so... they are only held on by 4 screws.
Old 12-11-2009, 11:25 PM   #15
JINT
JINT's Avatar
one of my buddies 540ia headlight fogged up and stays like that. Light expired already?
1990 M5 Euro
