Old 11-13-2009, 05:32 AM   #1
solosprints
Fan Controller broken?
Hey guys i have a problem with my e30.
The fan only turns on at 4.
1,2,3, do not work. What will i have to replace to get it working?
solosprints is offline   Reply With Quote
Old 11-13-2009, 06:07 AM   #2
Google E30 fan resistor replacement. Its a board with resistors on it, located under the cover in front of (attached to) the blower motor.
Old 11-13-2009, 09:02 AM   #3
about 40-50 bucks from dealer. Fan resistor gone. you can take it out and clean up the contacts to make it work again. but not sure for how long it will last.
Old 11-13-2009, 09:57 AM   #4
dmytro
dmytro's Avatar
Wow when did resistors start to cost that much, they go for like 5 cents. If you know how to solder.
dmytro is offline   Reply With Quote
Old 11-13-2009, 10:23 AM   #5
supernaught
supernaught's Avatar
They're also inductors. Never tried soldering in normal resistors.
See: $23.48
http://www.autopartsway.ca/autoparts...W~325is~242304
But make sure you get the right one.
Old 11-13-2009, 12:50 PM   #6
solosprints
http://e30.bmwdiy.info/blower-resistor/index.html
found a great link....thanks guys!
Old 11-13-2009, 12:52 PM   #7
ryanjv
ryanjv's Avatar
Send a message via MSN to ryanjv
not those kind of resistors, these are basically just coils of thick wire on a plate. the little color coded electronics store resistors are for smaller circuits and wouldn't handle the load.
i got mine on ebay, it was about $20
ryanjv is offline   Reply With Quote
Old 11-13-2009, 02:13 PM   #8
They're not really inductors, just wound coil resistors. It's quite clever since they obviously through a LOT of heat with the current the fan motor takes, but that heat is sucked up into the fan motor and blown out into the car.
Old 11-13-2009, 04:00 PM   #9
supernaught
i found one at the Cookstown wreckers, $2
Old 11-13-2009, 05:41 PM   #10
tg07lq
if i may hijack, ive got an e30 here that will make a loud noise on anything above 2, sounds like something hitting plastic on plastic. im thinking but hoping not blower motor? thoughts?
Old 11-13-2009, 05:57 PM   #11
your hopes are ,well, "blown" fan baskets or bushing are packing it in. I got one if interested. you'll have to take off the cover and run the fan to see what is either interfering with the baskets or see if they are wobbly. pm me if interested.
Old 11-13-2009, 08:48 PM   #12
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
They're less than $30 if you don't buy from the dealer. Who buys stuff from the dealer other than trim pieces anyways?
Grow up and move on.
