Old 09-01-2009, 07:47 PM   #1
325isRED
325isRED's Avatar
Diff question... (lots of info provided)
92 325is 245K KM
Noticed a humming from the rear lately so I lifted the rear end, turned on the car, popped it into 4th and went to the back to listen.
The sound was coming from the dif for sure. There is oil in the dif, almost as full as it gets; it does seem a bit thin.
If the car is in neutral and I spin one wheel, the other wheel spins in the SAME direction.
If the car is in gear and I spin one wheel, the other wheel will spin in the other direction BUT there is A LOT of resistance; I can barely do it!
Tomorrow I will put in Royal Purple gear oil, but I doubt that will fix anything.
Whats my next course of action?
'92 325is 5sp
Old 09-06-2009, 05:29 PM   #2
archrival
E36 Addict
archrival's Avatar
From the info you have stated it sounds like you have a bearing out of the diff. Most likely a pinion bearing, not cheap when i checked into it last. If i were you i would contact Eurostyle and see how much for a used diff as it would be the cheaper route. Just make sure neither of your outer wheel bearings could be causing the noise you are hearing
Old 09-06-2009, 07:17 PM   #3
if the wheels spin in the same direction you have posi. when in neutral. keep in mind the reason it is difficult to spin is because it IS IN GEAR you are using arm muscle to work against the gear box, drive shaft and the diff. Lots of resistance will be felt regardless. The hum could be anything -sound also transfers. The most accurate way is either use a long screw driver and put it where you think the noise is coming from. Move the driver to different locations to see if the vibration/sound grows or diminishes. Wherever it is loudest is the source of your problem. Or you can use s stethoscope - gives the same affect but better. Pinion bearing or flange bearing(s) can be the issue.
Old 09-07-2009, 03:29 PM   #4
325isRED
325isRED's Avatar
I was thinking along the same lines. I'm going to hunt down a breakdown of our E36's differential to acquaint myself with it further.
'92 325is 5sp
Old 09-07-2009, 04:33 PM   #5
dejan_da_dude
E36-err
dejan_da_dude's Avatar
Goodluck, Hopefully its just the fluid, Diffs are expencive.
dejan_da_dude is offline   Reply With Quote
Old 09-07-2009, 04:52 PM   #6
325isRED
325isRED's Avatar
I've replaced the dif fluid, 1litre of royal purple and .5L Lucas.
Running slightly better but there still is a distinctive sound from the dif. I have come to the conclusion that there is something wrong with my dif; I'm just not sure what yet...
'92 325is 5sp
