Old 08-13-2009, 07:48 PM   #1
Steve30
Techno Viking
Steve30's Avatar
HID trouble
i recently installed zkw's and for some reason the left lowbeam rarely powers on. i tried switching bulbs and have checked the fuses so the bulbs aren't burnt out. i've also checked the plugs and they are in tight. could the ballast be blown? or could a connection be corroded? the light does come on sometimes (like 5-10 tries turning it on).
E36 ///M3 S54
STock 335i "The Punisher"
Old 08-13-2009, 10:48 PM   #2
LondonWraith
LondonWraith's Avatar
ballast, had the same issue last week replaced the ballast and problem solved
LondonWraith is offline   Reply With Quote
Old 08-13-2009, 11:01 PM   #3
Steve@ASPTuning
Possibly ballast. Are you also using a anti-error & anti-flicker module? Its basically capacitors that filter out electrical noise.
Steve@ASPTuning is offline   Reply With Quote
Old 08-14-2009, 01:02 AM   #4
Steve30
Techno Viking
Steve30's Avatar
i'm not using caps. i'm pretty sure its the ballast anyways because when the light actually worked it wouldn't fire up at the same time as the passenger side. it would light up ~1 second after.
E36 ///M3 S54
Old 08-14-2009, 01:58 AM   #5
Shafhan
Shafhan's Avatar
bro same here my pass light comes on 2 seconds after my driver plus my driver light goes frm off to on n the passenger goes frm offto warmin up to on n takes like 5 to 10 seconds to b as bright as the driver side. i say check the ballast gonna do mine soon
Shafhan is offline   Reply With Quote
Old 08-15-2009, 11:17 AM   #6
344i
344i's Avatar
Could be the ignitor cord that is bent or damaged.
344i is offline   Reply With Quote
