Go Back   maXbimmer Forums > maXimum Tech > 6/8 series
Old 06-16-2009, 11:06 AM   #1
Boxer2
The OPP loves my M5
Boxer2's Avatar
Question Self leveling suspension issue
the self leveling suspension on my E24 does not go up anymore for some reason, does anyone know what to look for to start diagnosing the problem?
cheers
Rene
My Garage:
1986 328is (M20 Stroker)
1986 535i (5sp all original)
1990 325iX (Mint 5sp all original)
1989 325iX (Winter auto X car)
1991 M5 x2
1988 M6
2001 740i (Supercharged)
1999 528iT (summer DD)
2004 X5 3.0i (winter DD)
Boxer2 is offline   Reply With Quote
Old 06-18-2009, 10:20 AM   #2
e24_635csi
still wants a turbo...
e24_635csi's Avatar
i think it runs the same as the e34.
Check the accumulators, those little bomb looking things http://forums.roadfly.com/forums/bmw...6503297-1.html
Check for any leaks around the top of the shocks, and the lines that go to them.
If the same as the e34, they have a dual stage power steering pump that also runs the SLS system. make sure its not leaking, and is filled up. ONLY run Pentosin 7.1. It should be marked on the resevoir
I had the same problem in my M5, When i bought the car it would sag so low, and wouldnt come back. and the car was terrible to drive.
the seals go in the shocks and are virtually impossible to fix, and replacements are expensive. but I had found a used set from a member here.
Your other option is a SLS delete.
hope this helps.
e24 635csi -e28 528e/m30b34 - e28 M5 - e34 M5 - e46 330xi M
e24_635csi is online now   Reply With Quote
Old 06-18-2009, 02:14 PM   #3
Boxer2
The OPP loves my M5
Boxer2's Avatar
^ thanks for the info, and the link, I got myself a copy of the e34 bentley manual, between that and your link I should be able to diagnose the issue.
cheers
Rene
My Garage:
1991 M5 x2
1988 M6
Old 06-19-2009, 10:11 AM   #4
Boxer2
The OPP loves my M5
Boxer2's Avatar
where could Pentosin be purchased from? other than the stealership.
My Garage:
1991 M5 x2
1988 M6
